Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-27-2004, 09:44 AM
machinerepair machinerepair is offline
Lifter noise
I have a 97 wrangler, 4.0, 70k miles. Have what appears to be a lifter noise. Removed valve cover, pushed on valves. When pushed on No. 6 exhaust valve the noise went away. Replaced all the lifters. Same noise, same place. Swapped push rods and rocker arms. But the noise stays in the same place. Had the exhaust manifold out and welded 6 months ago. If I push on the valve while running, the noise goes away. Any ideas what to do next?
Old 08-11-2004, 11:08 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Lifter noise
Pushing on the valve? That might be your problem, might be a worn valve seal or problem with the spring.
Sounds like you've changed everything else in the valvetrain (except the cam, but doubt it's coming from there)
