Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 07-27-2004, 08:18 AM
raldo_gtm raldo_gtm is offline
Air Bag Code 23 Repair Info
My air bag light has been blinking a code 23...."Memory Clear Circuit Improperly Grounded". Does anyone know any ideas on where he ground is supposed to be? Any input would be helpful. Thanks!
Old 07-28-2004, 05:19 PM
Car Pal Car Pal is offline
Re: Air Bag Code 23 Repair Info
usually the grounds are pretty close to the ecu,i would check for a loose connection.
Old 07-29-2004, 08:02 AM
You mean the Air Bag ECU right? There is an ECU and an Air Bag ECU. They are different systems.
Old 12-27-2004, 01:42 AM
Mohner Mohner is offline
Check your clock spring!
I had same problem initially and then after awhile my horn and cruise control stopped working as well. When I pulled the stering wheel/column apart found clock spring wiring harness brittle and broken.
Hope this helps!
-Mohner
94 Bronco Eddie Bauer
