Old 07-26-2004, 10:39 PM
roach2k2's Avatar
roach2k2 roach2k2 is offline
Send a message via AIM to roach2k2
Problems
I got a 91 Eagle Talon, N/t Front wheel drive and my dome light, power locks and my radio wont work? Does anyone know what could be the problem? and how i Could fix this problem? Thank you.
Old 07-27-2004, 12:18 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Problems
Hard to tell with us not knowing anything about it. If you have a basic knowledge of electronics, check it for power and a good ground. There's not much repairing to do on electronics, only replacing.
Old 07-27-2004, 01:12 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Problems
#1 check your fuse's
DSM geek
Old 07-27-2004, 01:40 AM
george536's Avatar
george536 george536 is offline
Re: Problems
yea most likely the fuses. on my gs it seems they juss like burning out for some reason.
Old 07-27-2004, 10:13 AM
roach2k2's Avatar
Re: Problems
Is there a Fuse for those 3 things? and if so how do I know if they are bad? How Much do they cost?
Old 07-27-2004, 10:34 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Re: Problems
The owners manual has a fuse diagram.
Kris
2012 Genesis Coupe 2.0t
Old 08-01-2004, 04:26 PM
roach2k2's Avatar
Re: Problems
Well I checked the Fuses and that wasnt the problem. Is there anything else I can do or does anyone have any other idea. Help would be grateful. Thank you.
Old 08-01-2004, 07:18 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Problems
when u use the power doors do u hear a sound like when u push the button or is it silent?
if u hear a sond that means that the electrical works but the motor is shot or there is a mechanical problem.
if you dont hear a single sound ur electrical is shot and u got big problems
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 08-01-2004, 07:34 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: Problems
yep, fuses, nearly 80% of the time.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-01-2004, 11:37 PM
roach2k2's Avatar
Re: Problems
I dont hear a sound so it must be an electrical problem. Big problem? What can I do about htis and how big of a problem is it.
Old 08-02-2004, 12:06 AM
HotCrew's Avatar
HotCrew HotCrew is offline
Send a message via AIM to HotCrew
Re: Problems
To keep from blowing fuses you can get a circuit breaker fuse and that will help you figure out the problem while saying you some money on fuses!
Check out my site
After Night Groove Team Site
RS-T Build Up Site
http://www.angelfire.com/pro2/rst
