Old 07-26-2004, 10:31 PM
BigFig15 BigFig15 is offline
Send a message via AIM to BigFig15
2000 GTP Performance Chips
Im planning on buying a 2000 GTP. I was wondering where can I buy performance chips and who makes the best one. What other mods should I do? Id like to put out the same HP as a stock Camaro Z28.
Thanks
Old 07-27-2004, 08:40 PM
leadfootGTP's Avatar
leadfootGTP leadfootGTP is offline
Re: 2000 GTP Performance Chips
z28 puts out a little over 300 i think, most chips out for gtps are programmed to run with aftermarket exhaust, smaller pulley, and cool air induction. Ive heard nothing but good things about the "Digital Horsepower Inc. v1.0 PCM" the chip exhaust intake and pulley should put you well above 300 hp
stock gtp - 240hp
msp cool air induction system - 23hp
exhaust - ~ 10-15 hp
pulley 25-35+ hp (depending on size v pulley, DHP chip designed for 3.25-3.4" pulley)
DHP chip - 20 hp
final ~ 320+ hp (probly around 260 whp)
Old 07-27-2004, 08:42 PM
ps, you can buy all v this at 3800performance.com
itll probly cost a little over 1000 plus installation
( i donno how much of it you can do yourself )
Old 07-27-2004, 11:31 PM
Cool. I just bought it today! Can I add subs and a amp to a stock radio? Where should I get the windows tinted? What percent should I use?
Old 07-28-2004, 12:39 PM
cfaris cfaris is offline
Send a message via MSN to cfaris
you will need a high-low level wiring converter to add the amp and subs to the stock radio. I know cuz i just did it to my 04 GTP.
Old 07-29-2004, 12:21 PM
phaelax phaelax is offline
i got subs in my '00 gtp. I just took the wires from the rear speakers and hooked them up to this little box thing.(dont know what its called) It just simply takes the wires and gives you RCA plugs you can use for the amp.
Old 07-29-2004, 02:01 PM
that is what I was referring to by a hi-low level converter.
