Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 02-01-2002, 12:42 AM
6'5 285lb in a G20 6'5 285lb in a G20 is offline
header question
I need a header for my G and I wanna know if the Pacecetter header will fit on my 91 G and if its any good(hp gains,problems)also if the non ceramic coated one is OK
Old 02-01-2002, 09:51 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
If you get a Pacesetter for a G20 it will fit. They are OK. Coating or not doesn't really matter.
Old 02-01-2002, 08:57 PM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
I prefer ceramic coated.
nightmaR3Z
Old 02-02-2002, 11:26 AM
G-Forces's Avatar
Banned
Well it does look nicer but the coating you usually get on headers really does nothing for performance. They claim it's a heat resistant ceramic but it doesn't really do anything about the heat like a true ceramic coated header would. I.e. Swain white lightning coatings.
I wanted to buy my HS header uncoated so they could send it to Swain for that coating but they wouldn't sell it that way. Oh well no biggie I'll get my turbo bits decked out in swain coatings.
Old 02-02-2002, 08:48 PM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Not to dis on any header...but what headers have had problems with cracking or reliability?
-Brian Jones
I got a snake man
Old 02-02-2002, 09:35 PM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
Ya, Pacesetters are known to crack and are also said to be a direct ripoff of the Hotshot header.
Troy P.
My "pretty-much-stock" G20
:apoke:
Old 02-03-2002, 06:25 PM
nis.k.a.'s Avatar
This may be true in some cases. But ceramic coating won't stain like (ironically) stainless (i.e.- the infamous rainbow bends and fingerprint). Though not as effecient as Swain, it still will insulate the tube which in turn speeds exhaust velocity. Considering this is probably the best on the streets without going through Swain, I'd say it's definitely worth the money to go HS ceamic. Seeing as how they have 4 generations of header design tells me they were continuously looking to better on the older design. This and word of mouth (which there is a lot of) should be more than enough to see that HS is the obvious choice.
nightmaR3Z
Old 02-03-2002, 09:09 PM
NismoPC's Avatar
NismoPC NismoPC is offline
I heard the complete opposite. There are a few guys on here that have had their HS headers crack. As far as the Pacesetter goes, it is a copy of an earlier HS generation header, and is much cheaper and more mass produced, but I haven't heard of any cracking. The black "shipping" paint coat cracks off, but I have not heard much about the actual header cracking.
There is a thread on an HS cracking or the lower flex pipe actually, just recently titled POS HotShot Header here:
http://www.automotiveforums.com/vbulletin/t24738.html
Brandon
'96 G20 - modified
Old 02-03-2002, 09:40 PM
frogg's Avatar
I've heard the Pacesetter breaks more often on the Hotshot because it doesn't even come w/ a flexpipe which causes more stress and bending. The flexpipe problem is most likely a problem w/ the motor mounts.
Troy P.
:apoke:
Old 02-03-2002, 09:45 PM
[quote]Originally posted by NismoPC
[b]
I heard the complete opposite. [quote]
Heh..this is why I asked the question cuz Ive been hearing two different stories...people saying HS cracks, and that their HS is fine. Soo maybe we could get some data? Or someone that has this kind of data?
-Brian Jones
I got a snake man
Old 02-03-2002, 09:48 PM
frogg's Avatar
Both are subject to cracking under certain circumstances but I would go w/ the Hotshot because they are more "improved on" than the Pacesetter.
Troy P.
:apoke:
Old 02-03-2002, 11:30 PM
paradyme paradyme is offline
Lightbulb
Try the STILLEN 4into1.
:flash:
paradyme
95'G20t/AUTO/BLK
STILLEN HEADER/INTAKE/JWT/ECU/S3 CAMS/P11 99 G20 RIMS/
VIPER SECURITY/w/ REMOTE START/ ALPINE AUDIO
Old 02-04-2002, 09:36 AM
G-Forces's Avatar
Banned
:flash:
If you're going to get a 4into1 get the AEBS header. Better than teh HS in some aspects but it has its down sides like difficult installation and the fact that it hangs lower than the lowest part of car.
Old 02-04-2002, 09:47 AM
Hmmm...you make a good point. Do all these new aftermarket headers hang lower than OEM? Could this be a problem of hitting it, especially when the car is lowered?
-Brian Jones
I got a snake man
Old 02-04-2002, 02:02 PM
G-Forces's Avatar
Banned
I know the 4-1 AEBS header does. Excellent header BTW. I'm not so sure about the Stillen 4-1. All the 4-2-1 headers I know about are OK and don't hang any more than the stock pipes.
