Old 07-26-2004, 06:55 PM
nofxer84 nofxer84 is offline
fan not working
Hi and thank you to all of you that helped me with my heater core......I also found out that my fan is not coming on at all.....so i disconected it it tested it to see if the fan motor was ok..and it is there are no burnt fuses or anything could you please tell me what is wrong and how to fix it
Old 07-26-2004, 07:23 PM
Z-24CHEVFAN Z-24CHEVFAN is offline
I just had a similiar problem. My fan wasn't working at the lowest fan setting. It turned out to be a blown blower motor resistor. It is located near the rear of the blower motor. If you test for voltage using a meter and find that there is no voltage present (open circuit) at the blower motor connector at one speed setting or more, check the resistor for opens. I assume you have already checked the motor itself and saw that it worked. Hope this helps.
