Old 07-26-2004, 06:02 PM
Red 99 Mustang's Avatar
Red 99 Mustang Red 99 Mustang is offline
Send a message via AIM to Red 99 Mustang
air scoop thingys
i wanted to konw if u can take those lil plastic things that looks like air scoops off? and on the hood it u can actauly make it into a real airscoop cuz that looks lika stoopid wit a lil plastic cut off thing, it would betta if it really was 1 does n e one know how to make it into one?
Old 07-26-2004, 08:13 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
What scoop are you talking about? Did someone put a plastic hood scoop on your car before you had it, or are you talking about a stock scoop? If its stock, you can modify it with much work to be functional. If it is a stick-on, alot more work(a ton) is required to make it functional. If it is the stick on, you would need to cut a hole in your hood, get some fiberglass matting and resin, and shape it into your hood. Obviously, this is an extensive body mod and you probably wouldnt want to take the job on. If it is stock on the other hand, you can just drill out the fake honey-comb holes(VERY CAREFULLY!!) and run ducting to your air intake. This would require a custom air box able to snugly fit an air filter. So in the end, it would be neat, but not neat enough to actually do it. Hope this helps.
Old 07-26-2004, 08:20 PM
FordJunky FordJunky is offline
Send a message via AIM to FordJunky
well, id suggest gettin a shaker hood scoop (mach1)... ud prolly have to get a new hood (look on ebay for a hood off a mach1, they get parted out all the time one ebay and u could get one for pretty cheap) then its pretty easy... modifying the one uve got would be really hard and if ur not pretty skilled could end up costin a lot more.
Old 07-26-2004, 08:36 PM
stang_guy stang_guy is offline
look at this. its from SVTPerformance and the guys name is shaved99gt
Huge ass aluminu rear wing? $250
Chrome coffe can weed-eater muffler? $125
Spanki'n a wannabe import by 28 car lenghts........
PRICELESS.
Old 07-26-2004, 11:57 PM
ok i noe about the hood..but the plastic honey comb thingys on da sides r annoyin, wut would happen if i removed them?? whats behind them?
Old 08-01-2004, 09:51 AM
73mustang351c 73mustang351c is offline
The honeycombs are for looks. Now the question is do you want the scoops for extra air to pass over the engine to help with cooling or for ram air. If you are going with the ram air here's some words of advice. Ram air is expensive for the benefits. You will not see any gains in power until you reach 150+ mph. The only exception is tunnel ram air, which is very expensive. As for cooling, the amount of air entering the engine compartment will be minimal and not much help. If this is just a question of looks, then you can buy an aftermarket hood with a high rise cowl and no fake scoops.
I hear people say the Clevland is dead. Well they have never raced mine.
Old 08-01-2004, 10:11 AM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: air scoop thingys
I have to say a ram air hood is great for cooling down your engine. If you do not believe me when you put one it remember where your temp. gauge normally ran and see where it is with a ram air hood.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 08-01-2004, 02:21 PM
Re: Re: air scoop thingys
please remember that the engine must stay within 180 - 210 degrees for it to operate normally. Adding a ram air scoop for nothing but cooling the engine compartment causes the engine to stay under the 180 mark for longer. that causes the thermostat to stay closed longer and in the winter that is a bad idea.
Old 08-01-2004, 02:27 PM
fordforlife's Avatar
fordforlife fordforlife is offline
you could take the side scoops off, but if its an older car, your paint might not match with the paint underneath. it would be a slightly darker and richer color. especially if your paint is slightly faded or oxidized.
Old 08-01-2004, 08:20 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: Re: Re: air scoop thingys
195 for a comp controlled car. I've given this some thought too, thunderbird muscle, 'cause we all know how Ford EFI engines like a cold intake manifold, I've been considering putting on a 428 CJ style scoop right over my manifold to cool it a bit...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 08-01-2004, 08:27 PM
I was just saying it cooled it down. I didn't say put it on just to cool it. I put mine on because I liked the way it looked!
