Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 07-26-2004, 07:01 PM
redrick2456 redrick2456 is offline
1991 Nisan Sentra SE-R 2.0
Just changed one caliper and all pads on rear brakes. Now I'm getting the brake and battery warning lights on the dash. Had the alternator checked; it is fine. Made Sears replace the Gold Diehard battery even though it checked out ok. Starts fine, if the car runs for a while both warning lights go out. I'm thinking it is an intermitent electrical problem. I can hear what sounds like a relay switch under the dash on the drivers side clicking. Any thoughts would be appreciated.
Old 07-27-2004, 05:41 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: 1991 Nisan Sentra SE-R 2.0
Did you bleed the brake fluid after changing the caliper? How did you get the piston back in on the caliper that you did not replace? Check your brake fluid level in the engine bay and if it is low, put some DOT 4 brake fluid in there or maybe a complete brake fluid flush to verify that is not the problem?
Let me know how you go...
Old 07-27-2004, 02:22 PM
Re: Re: 1991 Nisan Sentra SE-R 2.0
Thanks for the input. Yes, I bled the brake fluid and it is not low in the engine bay. I have a nifty little tool that allows me to force the piston back in order to put the caliper on. Everything in the brake department appears to be working just fine. Any other ideas?
Old 08-01-2004, 02:28 AM
sarsourus sarsourus is offline
take the battery wire off the battery for like 10 minutes, then put it back in, then take out the battery sensor for 5 minutes then put it back in, if this doesn't work check it at dealer
Old 08-02-2004, 08:38 PM
shortysdrop's Avatar
shortysdrop shortysdrop is offline
Thats your solution for everything isn't it? LOL
I would track down the clicking noise and inspect the wiring near it.
Try pulling out the fuse for the instrument panel, start the car, turn it off and replace the fuse. See if it makes a difference.
Old 08-03-2004, 01:19 AM
not always
it makes the ecu recheck the problem and it wil make sure that nothing else is damaged.... u have a sentra, i suppose u should know that !!!
Old 08-03-2004, 02:21 PM
4doorDET 4doorDET is offline
Send a message via AIM to 4doorDET
i had the same problem and it turned out to be the alternator....
fredo
1994 4 door BBDET auto - manual swap club 16" enkei rims,3'' custom cat-back ,5zigen muffler, GC coilovers, KYB AGX adjustable shocks, drifter bodykit
www.ClubNismO.com
Old 08-03-2004, 02:24 PM
Re: not always
Relax I'm not H8'N.
