Old 07-26-2004, 05:11 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Dejontool Upper Intercooler pipe
ok, im buying a upper intercooler pipe for my 2g gsx. i've decited on Dejontool over road race engenerring & dave' Uicp becasue of the options avaliable. I would like to know when buying the "L" pipe, should i splerge and get the "S" pipe to make it a total upper hard pipe setup? is it a good HP/$ idea? or is that "S" pipe not worth the $ for the perfomance gain that i'll be reciving, or is it more just for looks??
Thanks.
DSM geek
Old 07-26-2004, 05:39 PM
Nstyle29's Avatar
Nstyle29 Nstyle29 is offline
Send a message via AIM to Nstyle29 Send a message via MSN to Nstyle29
Re: Dejontool Upper Intercooler pipe
I splurged myself and got the "S" and "L" pipe, looks good not sure how much difference it made in the hp area though. I liked my choice might as well go with all hardpipe...relatively inexpensive compared to other pipes.
Check out my 95 GS-T --> http://www.cardomain.com/id/nstyle29
Old 07-26-2004, 05:44 PM
did you feel alot of performance gain with the L pipe?
DSM geek
Old 07-26-2004, 06:52 PM
so, did you feel alot of performance gain with the "L" pipe
DSM geek
Old 07-26-2004, 10:27 PM
Nstyle29's Avatar
u do feel gain but not immense, but it is a must
Old 07-27-2004, 12:27 AM
joemathews's Avatar
joemathews joemathews is offline
Many people do 1g or aftermarket bov at the same time as upgrading the L pipe, so it's hard to tell whether the car is faster because of the more boost retained or the less restriction of the L pipe. It is certainly a necessary mod to get an L pipe, and you will definitely feel more power over stock! Try to find someone who bought an adapter for the 1g bov onto the 2g plastic pipe...they should know
1996 Eagle Talon
Old 07-27-2004, 01:04 AM
ahh, i just bought a 1g bov off ebay tonight, i plan on putting it on with the uicp. i actually plan on upgrading the intake, filter, mbc, & bov at the same time, and of course a gauge. i just want to know if the S pipe is worth the $ for the gain you get out of it.. so if anyone can tell me, i'd really appricate it..
DSM geek
Old 07-27-2004, 02:54 AM
kjewer1 kjewer1 is offline
AF - Advisor
Going full hard pipe is more about reliability than power gain. That soft rubber hose can fail, and its under that mesh so its hrad to tell. If you have a stutterbox or an automatic, build some boost with the hood open and you can see that thing expand a lot. It'll do it in a pressure test as well of course. I Got rid of mine long ago. The nly good thing about the stock rubber pipe is that it comes off easy
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-27-2004, 03:00 AM
so you believe its 80 well spent?
DSM geek
Old 07-27-2004, 03:02 AM
AF - Advisor
Thats hard to judge. If youre trying to be a low budget hero, I'd spend the money elsewhere. If you want a little more piece of mind and 80 bucks is worth it to you, might as well get it over with while you are ordering from there anyway. You're call
Kevin Jewer
Old 07-27-2004, 03:13 AM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
just get the l pipe and the 1g bov....the other stock "pipes" arent too restrictive....spend your money on removing more restrictive shit in your car
Old 07-27-2004, 03:15 AM
and about the gain....you will see more high end torque but below 4000 rpms you wont see much of an increase so dont be too worried about it....just my experience
Old 07-27-2004, 03:22 AM
80 is only a couple bucks shy of a 190 pump..
DSM geek
