Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 07-26-2004, 02:34 PM
jlkoko jlkoko is offline
'95 Pathfinder speakers not working
My Pathfinder was parked for a few days and when I went to start it, my battery was weak and the vehicle would not start. I jump started it and drove it home (the radio and speakers worked fine). At home, I put it on a portable charger overnight to see if the battery would be OK. It charged some but not enough to turn over the motor; my neighbor tested the battery w/a portable tester and found out it was junk. I replaced the battery, connected everything up and the motor turned over and started easily. No problem....except that none of the stereo speakers work. The radio turns on and lights up but the speakers (front or rear) do not work. Any ideas? Is there a fuse separate from the radio someplace that could have blown due to the monkeying around w/ the battery? Thanks.
Old 08-15-2004, 09:29 AM
nando4 nando4 is offline
Re: '95 Pathfinder speakers not working
Hi, I have the same problem,please let me know if you findout first. THANKS.
Old 08-16-2004, 12:57 PM
grunyon grunyon is offline
Try under the hood I believe on the passender side up front by windhield a black box had additional fuses. It's possible the factory amp has blown as well. Hope this helps!
Old 08-28-2004, 07:29 PM
maverick50616 maverick50616 is offline
Send a message via Yahoo to maverick50616
i have a 94 Pathfinder LE and had the same problem after replacing the radio. these vehicles have factory amps that power the speakers. one amp for front speakers and one amp for rear speakers. both my amps were located behind the passenger side panel in the rear cargo area and had a fuse on the side of them which were blown, after freplacing the fuses, the speakers worked great. some pathfinders had one of these amps installed behind the radio instead of both being behind the panel in the rear of the vehicle. i hope this helps.
Old 01-05-2005, 08:00 AM
joedptro joedptro is offline
Send a message via Yahoo to joedptro
Had same problem
AUDIO fuse fixed it... upper level far left on my 95
