Go Back   Automotive Forums Car Chat > Ford > Contour
Old 07-26-2004, 01:51 PM
kayross27 kayross27 is offline
car revs up by it self....
My 95 started revin up while its idling.. it doesnt go really high though.. it never used to do that.. any one know what the problem might be?
Old 07-27-2004, 12:48 PM
ggcatt ggcatt is offline
Re: car revs up by it self....
Could be leaking inlet manifold gaskets. Mine did the same thing, but rev-up was erratic. Cost me $500 to repair, now runs great.
Old 07-28-2004, 03:03 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
is it the V6 or 4 cylinder?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 08-01-2004, 08:48 PM
its a 4 cylinder
Old 08-01-2004, 10:29 PM
Car Pal Car Pal is offline
turn the climate control to off and see if it goes away.
Old 02-27-2005, 09:53 PM
Ok, problem is back
Ok, now the stupid thing will really rev. Last night i was at a drive thru and it did it once. the car was just in idle and all of a sudden it did it, then the car was fine the rest of the night. i got up early this morning and drove maybe 40 miles north and it ran fine the whole time then leaving the place i was at i was able to keep my foot off of the gas and the car went like 10 mph by it self, which is really weird, usually i have to baby it when im going slow. then i stop by safeway and when i turn the car on again it revs up really high ( i dont have a tach so i dont know how high) for 10 seconds or so then laid off and when i put it in gear to leave the parking lot i had to hold the brake down instead of pushing the gas... oh yeah, then the check engine light came on. about 30 miles down the road heading home all of a sudden it kinda kicks, like when you slam the gas hard it jumps to catch up or w/e but not quite so hard, then went like that for a few seconds, dropped off, then the light went off. then it did it 2x more then the light came back on. I got home, turned the car off and on then it reved way up again...it does it ever time i turn it on.. any ideas?
manual '95, 100300 or so..
Old 02-28-2005, 12:30 PM
I would guess the hanging rpm's is being caused by a sticking iac valve.
"The CEG Nazi"
www.contour.org
