Old 07-26-2004, 01:37 PM
KylePBZ's Avatar
KylePBZ KylePBZ is offline
96 vortec 350 problems, hard starting and cutting out
Ok, I've got a 96 1500 with 350 vortec with 130,000 on it. It is somtimes hard to start when cold(have to crank it over and over for a few minutes) it also cuts out momentarily when driving(part throttle when under a load). Doesn't always run bad and doesn't always start hard.
I have replaced, gas tank(was dented), sending unit, fuel pump, fuel filter, fuel pressure regulator, air filter isn't old, cleaned the throttle body and upper intake cover and idle air solenoid, plugs, wires, cap and rotor have about 15k on them, also changed the TPS, 3 of the 4 O2 sensors(2 were really bad, been a while ago though). Only thing I know that it needs is exhaust, it's lowered and i had to cut it off before the rear end then the rest broke off about 2 feet after the cats. I haven't found a place around here to do it.
Somebody give me a clue on this thing, please!!!
Old 07-27-2004, 12:23 PM
KylePBZ's Avatar
Re: 96 vortec 350 problems, hard starting and cutting out
I guess no one knows?
Old 07-29-2004, 03:57 PM
KylePBZ's Avatar
Unhappy
Well, I thought this was the place to come to but maybe not.
Old 07-29-2004, 04:11 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Well, it sounds like you've covered the basics that anybody on here would tell ya man. So that leaves some more serious problems (or a really simple one, like bad gas). You could have a lobe gone off of your cam. Or, it could be just those 130,000 miles showing up (especially if they have been hard miles). I do'nt know what to tell ya, other then to just take it to a garage, and get them to put it on an analyzer.
Also, your exhaust would have nothing to do with it, since it still has the converter (unless your converter is stopped up or partially stopped up).
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 07-29-2004, 08:16 PM
bbernhardt bbernhardt is offline
Send a message via Yahoo to bbernhardt
I'm not sure if this will be helpful to you or not, just taking a guess at the hard starts. I had a fuel pump relay going bad on me and it was a hard starter, only about $15 to replace and easy to do. I'm not sure if your's would be the same or not (mine is a '90), but once you turn the key on, you can hear the relay (kind of a buzz) sending fuel.
Just a stab at it, hope you find out what's wrong with it!
Bobby
Old 07-29-2004, 08:34 PM
KylePBZ's Avatar
Thanks fellas, I guess I'll just break down and take it to get put on the scanner. I just hate paying to have my shit worked on ya know.
