Old 07-26-2004, 01:56 PM
crx hf crx hf is offline
installing clutch disc?
Well i dont know if i put the clutch on backawards so before i get my car running i wanna know whats the proper way.When i first bought the clutch like 3 months ago it had a marking that told you what side went against the flywheel but know the mark faded and i need help does any one have pics?
Old 07-26-2004, 06:34 PM
91civicDXdude's Avatar
Re: installing clutch disc?
normally it will be scribed into the center of the disc. If you put it on the wrong way, chances are, it will go out in a month
Old 07-27-2004, 05:35 PM
Does the flat part go on the flywheel?Does any 1 have pics
Old 07-27-2004, 07:16 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
sorry no pics, but the spring hub should face the pressure plate, and the "flat" side should go towards the flywheel, mine did. If you put it in back wards you shouldn't be able to tighten the pressure plate bolts all the way.
