Old 07-26-2004, 10:41 AM
ditch946 ditch946 is offline
transmission interlock switch
hi
My1992 ford escort lx automatic transmission was in flood and after getting the engine started again the transmission will not come out of park when placing foot on brake.Any suggestions? thank you Steve
Old 07-26-2004, 11:58 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: transmission interlock switch
Beside the shifter there should be a small opening that is covered. Pull the cover off this opening and insert a straight blade screwdriver. This should release the shifter to allow you to shift the tranny.
Old 07-26-2004, 06:05 PM
Arnoldtheskier Arnoldtheskier is offline
On mine..93..(Cdn. car)the little cover is metal???..yes metal..AAAaand..LOL..when I went to "pry" it...(in poor light)..ROFL..I was having trouble "prying it"..it SEEMED that the thing wasn't prying..HUNH???..it "seemed" to be springing back...WTF?????.Mine is attached to a spring..and it SLIDES backwards horizontally with easy finger tip pressure.The first time this happenend in -30 weather I was told it was the trans.Oh well..200,000 something on it..SOOoo I left the car where it was and figgerred..I'd take a look at it.I guessed it COULD be a solenoid..THEN it was ok??..I KNEW one day I'd have to fix it.One day..I was ganderring through the owners manual in the glove box..THERE IT WAS!.DUH!!!!! No problem..just got out my pointed hat and sat in the corner for awhile...
Old 07-28-2004, 07:39 PM
Question seat belt motor shiff switch
Thanks for the help. I got the trans out of park and shifting but the relay which operates the lock does is not working, also I noticed my seat belt motor which bring the belt across you body isn't working either. Does any know if they on the same curcuit and how should I proceed .Remember the car was in water up to the windshied
