Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-26-2004, 10:34 AM
Rizmo Rizmo is offline
Send a message via AIM to Rizmo
heads on a d16 engine
what's up guys I'm new to this thread and looking for some advice on the following.
I have a stock d16 motor in my 98 civic LX. It's a 1.6L motor, I have a CAI and full cat back exhaust done. As far as the engine goes that is about it. I was looking to put an LS head on the motor as per advice from a friend. are there any better choices out there? and what are the performance gains I will see, and also are there other modifications I should do to make sure it will run right (I will be changing the headgasket obviously, but outside of that)? and are there any problems I might encounter doing this? thanks in advance for the help guys.
Old 07-26-2004, 12:13 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: heads on a d16 engine
you can't but the LS (b18b) head on a d16 motor it won't fit. They are in different family of motors; B vs D. You can only put a D-series head onto a D-series block. The best heads to use are the d16z6 or the d16y8; both vtec heads and should put you around 125hp. And most people with B-series motors use the LS block and get a vtec B-series head (b16a, b16b, b18c1, b18c5) put together. There is a swap guide at the top of the JDM Motor page, read thru that to help you decide what is better for you to do.
Old 07-26-2004, 04:04 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
z6 has the best flow but the y8 has a better shaped combustion chamber than the z6. doing a head swap is a good power adder for enignes without vtec
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
Old 07-27-2004, 08:13 AM
thanks a lot for your help guys. I thought it wouldn't fit yet my friend was set on the fact that it would. Now which head would be my best bet the z6 or the y8? I'm leaning toward the y8 since the combustion chamber is more properly shaped, is this a good move?
Old 07-27-2004, 09:35 AM
a few more questions guys:
if I do the head swap I have to change the ECU is that correct? And if so is this a difficult task (I'm better with mechanics the computer stuff adn electronics)?
Now is it also possible to just change the physical head and not touch the computer or anything else and will that give me any gains? I also know that VTEC motors have extra oil lines to the block b/c of the high RPM levels reachable. Do I have to do any modifications for that also or will the engine be fine with the normal swap?
Old 07-30-2004, 03:36 PM
civ92hatch civ92hatch is offline
Send a message via AIM to civ92hatch
Thumbs up
hey man, i have a d16z6 for sale. pm me!
Old 08-02-2004, 03:53 AM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
hey hey hey, just to clarify, i've heard and read somewhere that you can put a DOHC head (i forgot which one) on a d15a3 (si 87 rex block?) block. I think it was a d series ZC head on a D series block = so yes, you cant mix the B and D. = i could be wrong beacause i've never seem it done in person, but i;ve heard of people who believe!
Old 08-04-2004, 07:56 PM
jwjknorr jwjknorr is offline
Send a message via AIM to jwjknorr
the dual zc is a d series head buts its crap
