Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 07-26-2004, 12:01 AM
Ziggymidget5 Ziggymidget5 is offline
Send a message via AIM to Ziggymidget5
Resetting ECU on 1995 Si
I've searched around the forum and it seems there are different ways to reset the ECU depending on the car. I have a 1995 Prelude Si H23a, and I was wondering which fuse to pull and the battery way. I would like to know both ways, so if someone has knowledge on this, I'd greatly appreciate the help. Thanks.
White 1995 Prelude Si 5-speed 107,000 miles
AEM CAI
AEM Pulleys
DC Sports CC Header
Carsound Hi-flow Cat
5Zigen Fireball Cat-back
17" wheels with 215/40/17 tires
Custom paint on some interior (yellow)
Currently in Progress:
KMS (Honda-performance.com) Camshafts, Valve springs, and Retainers
Skunk2 adjustable cam gears
Wish me luck on this project, something always seems to go wrong.
My 1995 Prelude Si
Old 07-26-2004, 12:20 PM
510prelude 510prelude is offline
well the fuse way is to simply pull the fuse out and put it back in, the fuse box for a 4th gen i believe is loacted right infront of the "pop-trunk" lever therea litte box with a circular know on it, turn it counter clock-wise and take it off, you should see all teh fuse's now, look at the cover you just took off and it should have a blueprint of which fuse is which, look for the ECU one and just simple pull it out
the battery way is the easiest, just disconnect the battery for about 2 mins and then reconnect it.
Old 07-26-2004, 03:27 PM
juicy19 juicy19 is offline
Send a message via AIM to juicy19
Re: Resetting ECU on 1995 Si
All you need to disconnect is the negative battery cable.
2001 Honda Prelude SH
DC Header
3" Intake with K&N
GReddy Exhaust
Unorthodox Racing Pullies
JET enhanced ECU
10.3 OBX Plug Wires
Old 07-27-2004, 01:49 AM
Alright thanks guys, I reset it today after doing the fuel pressure regulator mod. We'll see how it turns out.
AEM CAI
AEM Pulleys
DC Sports CC Header
My 1995 Prelude Si
