Old 07-25-2004, 10:43 PM
97silverbulletgsx 97silverbulletgsx is offline
Banned
Send a message via AIM to 97silverbulletgsx
please help with bov question
i just put a 1g bov on my 97 gsx and the previous boost level was at 13 psi, but when i put the 1g on, the boost is now at 20 psi, i have tried turning it down with the turbo xs boost controler but it doesnt work. i think its something with the waste acuator. please help
Old 07-25-2004, 10:49 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: please help with bov question
turbo XS makes absolute crap (way too many bad experiences)... everything they make LEAKS, get a joe P instead. did you remove the BCS restrictor though btw?
The daily driver. The weekend cruiser. The lazy shop hog.
Old 07-25-2004, 10:52 PM
Banned
no, i just switched the stock 2g bov with teh hard 1g and it jumped over 7 psi without me touching anything else
Old 07-25-2004, 11:21 PM
joemathews's Avatar
joemathews joemathews is offline
First, stop boosting your car until you have this figured out.
A leaking TurboXS boost controller would cause you to run LESS boost rather than more...only at the right pressure does the the wastegate actuate, after the mbc's spring has been depressed.
Are you positive that you installed the mbc properly? Did you start with the bolt ALL the way out of the mbc assembly, then tighten it one or two turns at a time until you reached the desired boost?
What mods does your car have? You probably just need to loosen the bolt on your mbc, thereby making it easier for air to escape past the ball and spring and reach the wastegate at a lower boost level. Like I said earlier, start with the bolt ALL the way backed out, just threaded with 2-3 threads (just don't let it fall out ). You should be barely boosting (if at all) at this setting, maybe 4 psi depending on the boost controller and the spring you have. If you still boost past 15 psi with the bolt backed all the way out of the mbc, you have installed something improperly, or your mbc is faulty. Then it is time to re-check your installation based on the vfaq.com instructions. If you've done everything right, your boost controller is somehow jammed and the spring or ball is stuck and not opening properly--take/send it back and get a new one.
Hopefully you just have the bolt tightened down too much...let us know what happens.
1996 Eagle Talon
Old 07-26-2004, 02:07 AM
kjewer1 kjewer1 is offline
AF - Advisor
When diagnosing these problems, I actually prefe to bypass the BC entirely, and run a vac line right to the WG actuator from a manifold or turbo/uicp boost source. That takes improper BC setting, BC malucfunction, and spike out of the equation. If it still goes to high, you then have to dcide if its boost spike, or boost creep, and go from there.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-27-2004, 12:31 PM
TurbosR4me's Avatar
TurbosR4me TurbosR4me is offline
Im having a similar problem. Ive installed a hallman mbc and it doesnt seem to have any effect on boost. I turn it all the way out, and i run 12 psi, turn it all the way in, i run 12 psi.
When you bypass your bc, can you run your wg actuator line to the tee from your intake mani to your bov?
Btw, ive disconnected my wg actuator entirely, and I can run tons of boost (20+ psi).
Old 07-27-2004, 08:06 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Yes, intake manifold to WG actuator will give you WG spring pressure boost, 7 or 9psi on 2g's I believe. BOV line is a good boost source.
Old 07-27-2004, 08:26 PM
TurbosR4me's Avatar
Thanks joe. I had another question about the bcs. When you install an aftermarket bc, you do not need to cap off the bcs do you? I just left the wire connected to avoid CEL's and left the two openings...open.
Old 07-27-2004, 08:40 PM
JoeWagon's Avatar
Banned
I don't think the BCS disconnected can cause a CEL. I believe mine is out, but I remember not being able to get it off because of a bolt, so I honestly can't remember if mine is still plugged in. The opening in the intake pipe needs to be capped, if that's what you mean. So does the turbo boost source when you use a REAL boost source for your controller.
Old 07-27-2004, 09:15 PM
TurbosR4me's Avatar
Ya, both of those have been capped off since day 1. UPDATE: I just ran my car with the bcs completely disconnected with my actuator wired to the T in my bov line.
I ran about 10 lbs consistently. Does this mean my bcs is not working? Like I said, I have opened my bcs all the way, and im running about 11 lbs, and ive closed it all the way, and still run 11 lbs.
Ive always thought it was another boost leak. But my idle is regular even at hot temps, and I have tested for boost leaks with vfaq leak tester and found nothing. Is there any way to test your bcs? BTW, its a hallman mbc. Thanks
Old 07-28-2004, 12:18 AM
JoeWagon's Avatar
Banned
bcs and mbc are different. if you're sure that you had it open and closed at the same boost, it's broken. try a friend's MBC to see if it may be the car.
Old 07-28-2004, 12:57 AM
TurbosR4me's Avatar
BCS.....MBC.....too many letters make me confused. O_O I called a few fellow dsm owners to see if they have any extra mbc's, no luck yet. Thanks for the help Joe.
Old 07-28-2004, 01:08 PM
joemathews's Avatar
BCS=boost control solenoid (generally used to refer to the stock, factory solenoid for controlling boost)
MBC=manual boost controller (Hallman, TurboXS, JoeP, take your pick ) Technically, a MBC could also be called a BCS...but for communication's sake we just use BCS to refer to the stock solenoid
1996 Eagle Talon
Old 07-28-2004, 09:00 PM
TurbosR4me's Avatar
Yes....I know... It was a typo, lol. Nobody has any ideas for testing a hallman mbc?
Old 07-29-2004, 05:14 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
how i tested mine is i took the line running to the manifold off and hooked it up to my air compressor, then i took the line running to the waste gate and hooked that line up to my boost gauge... turned the pressure down to 25psi on the air compressor and turned the boost controller until it read 25psi... then i turned it back down until it read 0psi again!
