Old 07-25-2004, 10:36 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Axle removal
ive been getting some wierd sounds upon acceleration in my SI. so i took it apart thinking it could be a wheel bearing but my CV boot is ripped and there is grease all over. wheel bearing seems to be fine. my question is how do i remove axle from tranny to replace? also, do i need to drain tranny fluid before removing axle from differental (stupid question i know)?
thnks
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 07-25-2004, 11:49 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Axle removal
no just pull all the long bolts to like the tire rod and stuff so the tire is free hanging and yank the axle or use a fork which is best...but memer first thing you gotta do is get a 32mm axle nut to remove it...just done this a month ago to remove engine from a busted rod bearing
Old 07-26-2004, 05:08 AM
shadowb shadowb is offline
Re: Axle removal
make sure you drain the tran first ,or it'll be messy bro,remove the tire ,lower control are fork,castle nut 1-1/4 is what i use or 32mm . Use a big screw driver to pop the axel out of the tran and pull it out.
