Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 07-25-2004, 08:02 PM
Gebo Gebo is offline
Imaginary rumble strips???
3.8 with 190,000 miles. Somewhere between OD and D as the van is shifting between these two, the van will feel like I am running over those "bulldozer" tread marks like on the side of the interstater. Every now and then, I don't have an OD. What are my options?
Old 08-09-2004, 04:03 PM
90accord 90accord is offline
Re: Imaginary rumble strips???
I have a 1995 tran sport with the same prob I to would like to find some info
Old 08-09-2004, 05:47 PM
LMP's Avatar
LMP LMP is offline
TRy that
www.avigex.ca/34shift.jpg
If something looks like what you have, I may scan other pages to help
Old 08-09-2004, 10:21 PM
LMP's Avatar
LMP LMP is offline
Check this also....
www.avigex.ca/TCCShudder.jpg
Old 08-10-2004, 05:50 AM
I'm going under the wrench next week. I'll let you know after the operation. 2 A/T "specialists" think it is a bad Torque converter.
Old 08-30-2004, 01:55 PM
It was a bad torque converter. I used the plus 4 AT Chrysler fluid and it stopped it for 2 weeks. THe transmission guy recommended it saying to try it if I was not ready to go for a transmission job. ANyway, $1600 later, my transmission shudder is gone. HE rebuilt the entire transmission.
Old 09-04-2004, 12:22 AM
Stuart1003 Stuart1003 is offline
Gebo,
This is Stuart1003, holly moly...you have had your own share of problems in addition to the windows...Did you ever get the window problems resolved?...If so, then how?
Stuart1003
Old 09-04-2004, 09:40 PM
Yes, my final problem with the window was a loose connection in the wiring somewhere. I just moved the wiring in my door (everytime the window would stop working) until I found the area and then kept moving it around until I think I finally got it fixed.
Old 09-22-2004, 10:05 AM
Barry's94Transport Barry's94Transport is offline
Your problem may be just like mine....which I think is not transmission related ( check out the 2nd link by LMP). I do not understand why you say you do not have OD. It is my understanding that all the 3.8 engines came with the 4 speed, and the 4th gear is the overdrive gear.
Old 09-22-2004, 04:05 PM
IT was torque converter. AFter it slipped so long trying to go into OD, the computer would lock out the OD gear to prevent the continual slippage from the AT trying to go into OD from 3rd. What I meant was I only had 3 forward gears. It would not go into OD after the AT warmed up.
