Old 07-25-2004, 06:05 PM
94astro 94astro is offline
Front left pulls and vibrates when the brakes are applied.
Put new caplipers and no change. Any other ideas?
Old 07-25-2004, 10:36 PM
chris2000s10 chris2000s10 is offline
Re: Front left pulls and vibrates when the brakes are applied.
well the pull could be a bad brake hose.. as for the vibration you need to either replace or resurface the rotors.
Old 07-26-2004, 12:46 PM
RonB RonB is offline
Is this under hard breaking? Make sure the rear brakes are properly adjusted, and are doing their share of the work.
Old 08-17-2004, 02:31 PM
Warlock1025 Warlock1025 is offline
I agree with RonB, it may not be in the front brakes...
Old 12-06-2004, 09:11 PM
jpetillo jpetillo is offline
On my 2000, it was hard spots on the disks, and it pulled and vibrated. You can see the hard spots.
I had a bad pull on my '91, where it would change lanes to the left on you if you weren't careful - it was a collapsed brake hose on the right front.
Old 12-07-2004, 06:12 AM
liveinusa liveinusa is offline
Re: Re: Front left pulls and vibrates when the brakes are applied.
95 safari that pulls to left, how can you tell if
you have a (collapsed brake hose) ????
Old 12-07-2004, 06:23 PM
You may be able to tell by feeling the hose. But, you can certainly tell if one side is harder to bleed than the other. On my '91, when bleeding the brakes, the brake fluid just slowly dribbled out on the right side, but came out normally on the left.
Old 10-14-2005, 08:21 PM
ford next time ford next time is offline
Check your idler arms in your steering linkage.astro are known for them to go bad.
Old 10-17-2005, 08:27 AM
drew300 drew300 is offline
brakes
Also, these vans are known to wear out tie-rods and other front end parts that can cause vibrations and pulling.
With my van, the brakes cause a vibration from rust developing under where the pads sit. (from lack of use). A few kilometers of light brake application will get the rust off, and then it's fine.
Old 10-21-2005, 07:45 PM
Kings-x59 Kings-x59 is offline
two late thoughts.
an air bubble in the right brake line.
bad shocks. A crapped out shock will cause uneven traction, and as a result a pull to one side.
'89 Astro 4.3L Z
CFM-Tech power plate
2.5" exhaust, Low restriction cat and muffler
Jet stage I chip
B&M trans cooler
'96 Jeep Cherokee
'99 Chevy Cavalier
