Old 07-25-2004, 04:29 PM
mlund12 mlund12 is offline
1989 F-150 will not start.
Hello all, 89 f-150 with new plugs, wires, fule tanks, sending units etc.....will turn over and can hear the fuel pumps priming the fuel injectors, but it won't fire. I am pretty sure I am getting fuel, but not 100% as I am relatively new to fuel injection.
Any tips.?? The other day it fired right up, and I moved it 50feet in my driveway..............
Thanks
Old 07-25-2004, 05:24 PM
twistedpixi twistedpixi is offline
Send a message via AIM to twistedpixi Send a message via Yahoo to twistedpixi
Re: 1989 F-150 will not start.
Thanks
greetings from Louisiana,
My boyfriend has a 1985 F150 and has much experience in dealing with the same behavior from his truck. For years he and his mechanics researched and tried to find answers to this same problem. He said to write to you and to tell you that it is likely a relay. Check out any relay involved in the ignition system. He had this replaced and it has not laid down and left him stranded since. Good luck!
Old 07-25-2004, 07:06 PM
Car Pal Car Pal is offline
the relay is on the drivers fender well is by the air cleaner under a black cover and it's green
check for corrosion also in that general area.
Old 07-27-2004, 03:39 PM
Re: Re: 1989 F-150 will not start.
Thank you as well CarPal!!! I replaced both relays due to corrosion for $30 and it started right up!!
Michael
Old 07-29-2004, 07:05 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
do you have spark? If you do that is the same pickup which tells the pcm to open the injectors. Check to see that. Also, assuming you have dual tanks, there are 3 pumps. One in each tank and then one high pressure on the frame rail. Now single tanks are the same setup, you could be hearing the in tank low pressure pump, but the high pressure could not be running. Take a fuel pressure test.
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
