Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 07-25-2004, 03:40 PM
DUlrich1227 DUlrich1227 is offline
Send a message via AIM to DUlrich1227
Engine light keeps coming on
The car is a 2001 sonata 6 cyl
The engine light keeps coming on...Its been to hyundai 10 times so far...
the first few times the replaced vaious sensors..this last 3 time they said that it did not through a code so they said the put the computer back in "relearn mode" and drove..
well it has come on again
the vehicle has had all reccommended maint. done including new feul filter..
any suggestions or ideas ? any one else have this prob ? We opened a cliam with hyundai ? what can we do ?
Old 07-25-2004, 05:08 PM
vwhobo's Avatar
vwhobo vwhobo is offline
Re: Engine light keeps coming on
If I understand you correctly you're saying the "check engine light" is the one that keeps coming on. One helpful piece of information to have is whether or not the light is on when you take them the car or if it has gone out. The reason this is important is that if it's on when you take them the car they should have no problem retrieving the code. If it has gone out, depending on how many times you have started the engine since it went out, the codes may or may not be in the history. There are alot of variables, too many to explain here, so take my word for it.
At any rate, as many times as you've taken it to the dealer they should have come up with something by now. It sounds to me as though the place you're going has some incompetent techs and they're working on your car using the dartboard (or maybe the coin toss) method. Maybe it's time to look for a good independent shop in your area. Your best bet is to find one that employs ASE certified technicians. Good luck.
P.S. This is the nicest, most PC way that I know of to tell you the dealership you're using apparently has a group of idiots working there.
Old 07-25-2004, 06:05 PM
Re: Re: Engine light keeps coming on
Yes it is on when it gets there
We did change dealerships..
the last one said there was a transition code given and the computer needed to be relearned so thats what they did and its back on.
oh and yes it is the check engine light
Old 07-25-2004, 06:19 PM
vwhobo's Avatar
Re: Re: Re: Engine light keeps coming on
As I thought. I take care of lots of cars that dealerships (not just Hyundai) can't or won't fix. Hyundai dealerships in my experience should install stages in their service departments because it seems as though there is alot of tap dancing that goes on.
Notice I said "it's time to look for a good independent shop in your area". Forget the dealer and go to someone who wants to repair your car correctly the first time instead of just taking your money. Or you could take two asprin and call me in the morning. LOL
Old 07-25-2004, 08:10 PM
its still under warranty so thats why it goes to the dealership..
its just rather frustrating..
thanks
dave
Old 08-02-2004, 08:10 AM
equus's Avatar
equus equus is offline
Has the dealership told what the codes are? If you can post that here I might be able to help you.
Old 08-02-2004, 09:53 AM
yes they have and replaced various sensors
the last time it was there they said there was no code......
so the drove it in learning mode somethign like that
pulled the neg battery terminal and reset the computer
its back on again and going in tommorrow morning for the 10th time now
Old 08-02-2004, 11:25 AM
equus's Avatar
It still does not do much if they have not told you specifically what the Trouble codes are. I would recommend you ask them what the codes were that the ECM displayed on the Hi-Scan Pro. Any time the Check Engine Lite is ON there is ALWAYS a Trouble code stored that will be displayed...You cannot have a Lite on and not have any trouble codes...!! If you can furnish me that I would be more than happy to help you...
I thought I thaw a putty tat..I did..I did..
Old 08-02-2004, 07:34 PM
vwhobo's Avatar
Re: Re: Re: Re: Engine light keeps coming on
Just out of curiosity, how are you going to do that? A minimum wage flunky at Autozone can hook up a code reader and determine what the DTC verbage is. It takes a bit more than just a code to diagnose what the problem is, like maybe an actual scan tool and someone with the knowledge and experience to use it. Without being able to actually look at the car replacing parts based ONLY on the DTC simply makes you a somewhat educated parts changer. I'm not questioning your knowledge or ability, I don't know you well enough for that. However if you are knowledgable you know what I'm saying is true.
As for asking what the codes are I agree with you but... it SHOULD be printed right on the repair order. We have just a little too little information here to make any good calls, unless all you want to do is get some exercise by jumping to conclusions.
Happiness is a hot VW!
Old 08-03-2004, 05:07 PM
Rhondas Rhondas is offline
Re: Re: Re: Re: Re: Engine light keeps coming on
THIS IS WHAT HAPPENED AFTER THEY CHANGED THE TIMING BELT AT 55K.
Hi, I have the same problem with my wifes 2001 4 cyl sonata , its going in this Monday for the 5th time , the first was a throttle body cleaning , the 2 nd was a fuel injectioon service cleaning I paid for $115.00 had to eat it they said, 3rd visit a airflow meter replaced N/C still under the warrente ,4th time the spark ing. coil replaced,today the car missed a good jolt like the tranny down shifted and bingo the light is on , what is the real fix? why do they the so called techs have such a guessing problem? please email me. Thanks. [email protected]
Old 08-03-2004, 08:26 PM
equus's Avatar
Oh..I only asked that as I am a Field Service Engineer for Hyundai Motors!!!...I do get a lot of excercise!!!!...
Old 08-03-2004, 08:47 PM
vwhobo's Avatar
Re: Re: Re: Re: Re: Re: Engine light keeps coming on
Then you are fully aware that what I said is correct. It seems to me the best help you could give this poor soul would be to find out where he's having his car "fixed" and put the screws to them.
On another note, perhaps you can answer this question. One thing Hyundai does right is have the website hmaservice.com. Is there anywhere on that site (I've looked but didn't find it) or maybe another official site that has good illustrated parts breakdowns? Thanks in advance.
Old 08-04-2004, 08:05 AM
equus's Avatar
Re: Re: Re: Re: Re: Re: Re: Engine light keeps coming on
I cannot "put the screws" as you mention to any one..all I can do is to determine where and what the concern lies with the vehicle. Then to determine when the original concern started and what specifically was repaired at that time...If this owner would at least furnish me with that info and what the codes are now I might be able to steer him in the right direction..I donot have a "magic wand" to fix it over the forum nor do I have the capability to read minds. I can logically deduce what was wrong and what had to be checked to repair that concern. We do help the field techs over the phone thru our Tech-Line..so it is not such a deal that we take a shot in the dark to repair nor de we expect the tech to take a "shotgun" approach. There will be some techs who are renegades and donot follow the guide lines. I do feel for this owner that he has not been satisfied with the repair. YES he/she MUST take that Sonata to another dealer.
I donot want to get into any sort of a P***ing match on forums...I came in here on my own accord to check out this site and then registered so that may be I might be of some assistance as I am from the factory....evidently there are forces here and or members who don't appreciate this.
As far as the Parts Breakdowns are concerned it is a software that the dealer uses on line and requires a dealer code and password which I cannot divulge to the general public.
Still I will help ANY Hyundai owner here if they do need any assistance on the technical end......
I do appreciate the kind words you said about us having the Service Web site..we strive to enhance that part of service for the general public and I am pleased that you are using it.
If I can be of any further assistance please feel free to post....
Old 08-04-2004, 04:43 PM
vwhobo's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Engine light keeps coming on
If you haven't experienced forums before you'll find there are all sorts of people looking for that silver bullet that will cure their ills. Unfortunately they usually don't give you anywhere near enough info to work with. I guess it's tha nature of the beast.
Thanks for the info on the IPB's.
Old 08-06-2004, 08:41 AM
maschiller maschiller is offline
try new spark plug wires.
shot in the dark without a condom -- maybe?
it worked for my car.
new plugs too.
good luck. it seems to me that either your car is lemon or your service techs are lemons.
