98 jetta stalling out
Hey, first time here. I have a 98 jetta that stalls out under normal acceleration.It left me "jus_chillin" on the side of the highway last saturday.
It does this in all gears, i have to gently accelerate, somtimes it will jerk but when i let up off the accelerator it will idle normal, sometimes it will stall out. I have changed the wires ,spark plugs, distributor, rotor, throttle body. |
Re: 98 jetta stalling out
I would have it checked for codes toknow where to begin.
it had several
P1580-idle speed control aux. input P1582-idle speed control aux. input P0300-multiply cylinder misfire P0301-#1 cylinder misfire P0304-#4 cylinder misfire |
Ignition coil could be the source of your misfires. Mine did the same with a bad coil. Have you ever cleaned your intake and throttle body with intake cleaner and a rag? This may clear the other two codes. Good luck!
My (4 Jetta is doing the same thing and i was told it is my MAF sensor so im buying a new one if you figure out exctaly what it is Let me know.
Thanks |
Thts supposed to be 94' jetta
I dropped it off a the mechanic today
hopefully I'll find out in a coouple of days |
