Old 07-25-2004, 01:32 PM
unidos unidos is offline
1999 Tahoe Dual battery
I have a 1999 tahoe. how do I know if it has the wiring already installed to add a second battery? It already has the tray.
There is a long wire that runs from the battery across the front of the truck and ends at the underhood fuse panel what is this for? power for the fuse box or aux wiring?
Old 07-28-2004, 10:49 PM
Accord_boy619 Accord_boy619 is offline
Our 2500 @ work has dual batt. It wont be that hard to wire another batt. Just make sure you wire it in parallel. If you dont get get me, feell free to ask.
Old 08-03-2004, 06:55 PM
99Tahoe 99Tahoe is offline
Send a message via ICQ to 99Tahoe Send a message via AIM to 99Tahoe Send a message via Yahoo to 99Tahoe
What is the benefit of having two batteries? I have a 99 Tahoe and am thinking about adding a 2nd battery. Thanks!
Old 08-07-2004, 05:24 PM
Re: 1999 Tahoe Dual battery
I ended up going with an isolator
Old 08-09-2004, 01:12 PM
You get more crankin amps, you can run your stereo longer w/o the engine runnin. More juice basicaly
Old 08-13-2004, 01:18 PM
Jollymon247 Jollymon247 is offline
Will a dual battery system effect the alternator?
Old 08-13-2004, 02:54 PM
Nope cuz your car still goin to pull the same amount off load as if you only had one batt. Just make sure you hook it in parallel and NOT in series.
