hello! im a long time reader viewer and now i need some advice!! i have a 99 gt--stock, and when i drive the car and apply pressure to the clutch and switch gears, i hear an obnoxious whining..mind you this is only when the motor is cold. after about 5 min of running or driving it goes away...any suggestions????? before i bought the car i had a full out diagnostics check and all that shit checked out, but the motor was warm at the time of the test, so nothing was obvious..it kinda sounds like metal is rubbing againest metal, is there a way to lubricate it?? please help!!!!
p.s. should i start looking into purchasing a new king cobra clutch? thanks guys!!!!! |
Re: whining from clutch
well if something is screwed, why is it only when its cold??
That's just the way throw-out bearings go sometimes. They squeal when they are cold but quit once they warm up a little.
Not always that way though, my car is losing it's throw out bearing right now and it squeaks when my foot is right off the clutch. Soon as I push the clutch in, it quits. Doesn't matter if it's hot or cold.
yeah that seems like the case with me, but its only when its cold..it only lasts for about 5 minutes..depending on outside temp.
Mine squeels when I have the clutch pedal in, but if I keep taking taking my foot on and off the clutch pedal, it eventually goes away for a little while.
I'm having the exact same problem. Also I'm getting a squeaking sound when I press the Clutch Pedal in, must be the Clutch Cable. Is this stuff serious? If I need to get this stuff fixed I might as well replace the clutch disk and maybe get the flywheel resurfaced, since the whole shebang's gotta be opened
Sounds like the throw out bearing. Sounds kinda silly... but have u checked the clutch/brake fluid?
