Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-25-2004, 10:20 AM
algol algol is offline
1996 camry: check engine warning light
I have 1996 Camry. It has 105,000 miles. "Check Engine" light is on.
What does it mean? Sometimes when it it idling the engine stops. IT happened 3 to 4 times (but never in running). Any clues?
Old 07-25-2004, 11:22 AM
ToyotaTech1 ToyotaTech1 is offline
Send a message via AIM to ToyotaTech1
Re: 1996 camry: check engine warning light
you need to pull the codes on it with a scantool and then go from there it means that there is malfunction with one of the sensors
Old 07-25-2004, 11:34 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
algol,
If you have Autozone in your area they will check the code(s) for you for free.
Old 07-25-2004, 11:14 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
It's possible that your problem could be caused by either a faulty O2 sensor, converter, or throttle position sensor. As stated before, the only way you can get an accurate diagnosis is with the use of an OBD-II scan tool to retreive the diagnostic codes from the ECM.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
