Old 07-25-2004, 08:15 AM
bugfoot bugfoot is offline
Thumbs down 88 camaro 2.8 overheating probs
My 88 camaro is air conditioned and every thing works fine for about 30 mins and then I notice the air is blowing warmer and the water temp is rising. I have replaced radiator fan switch and coolant temp switch as well as the radiator fan relay with the same results. I have recently wired the fan motor direct with a switch for manual on and off and have had no problems with overheating but would like to fix it right. This camaro has a 87 build date but 88 on the registration. I don't have much experence with 2.8's mostly V8s. Also the car sat for a couple of years before I got it. Any help would be greatly apprecited, Jerry
Old 07-25-2004, 09:31 AM
chris2000s10 chris2000s10 is offline
Re: 88 camaro 2.8 overheating probs
does the fan work properly? come on when the a/c is on when the car is cold? leave the ac off and see if it comes on at about 200 degrees if it does a cooling system flush will probably help you out.. the radiator could be a little plugged
Old 07-25-2004, 11:34 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Consider replacing the thermostat with a 180 degree unit.
Old 07-25-2004, 11:52 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
check for blockages in between the radiator and condencer, leaves, plastic bags, ect. check for fan operation, coolant level, and such.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-26-2004, 02:29 AM
hellraiser319's Avatar
hellraiser319 hellraiser319 is offline
Registered User
flush the whole coolant system and make sure the thermostat is operating correctly. worst case scenario is a head gasket is startin to go. that happened on my moms firebird's 3rd engine. just make sure fans, thermostat, and fluid level and try flushin it a few times. should help ya out
Old 07-31-2004, 03:37 PM
Thanks, Guys !!!!
I have read and done most all the suguestions except the rad flush. I will do that on Sunday. thanks again for all the help Jerry
