Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-25-2004, 12:41 AM
98_accord 98_accord is offline
Frankenstein
I have a F23a (accord engine) I'm wondering if I'm able to use the H22a head on my block ... If so what I would need ???
F23a SOHC vtech
H22a DOHC vtech
Old 07-25-2004, 02:05 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
You can't.
Old 07-25-2004, 02:35 AM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
Re: Frankenstein
hmm, i say magic, yup magic would work
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 07-25-2004, 03:14 AM
91civicDXdude's Avatar
Re: Frankenstein
yes it is possible and people have done it. get an h22 head gasket and put it up to your f23 block and you will see that it is possible.
Old 07-25-2004, 10:57 AM
SiGNAL748's Avatar
teh wot fcuk
Old 07-25-2004, 11:30 AM
not able to do it right??
because cannot fit DOHC head on SOHC block right??
Thanx
Old 08-03-2004, 06:58 PM
jurrasic519 jurrasic519 is offline
Send a message via AIM to jurrasic519
Re: Frankenstein
only h and h go together and f and f series parts cant do a f block with a h head.
Old 08-04-2004, 06:07 AM
grimple1 grimple1 is offline
Send a message via MSN to grimple1 Send a message via Yahoo to grimple1
Re: Frankenstein
see signature...
all that is required is blocking 2 drain holes and swaping the internals of the waterpumps. you using an f23 motor will be ok with the f23 head gasket. just be sure to enlarge any holes that require you to do so.
Old 08-04-2004, 06:08 AM
Re: Frankenstein
the orginal guys that did this have over 5k miles on their engines. see honda-tech.com for more details. just search for f22 h22 head
