OK, So i'm planning on putting in a new pressure plate because a friend told me that I need one since my clutch is a POS. I've never really done anything that involves so much work. I have the chilton's book with the step by step crap telling me what to do so I think i'll be fine doing it, but is there anything that you guys can recomend that I do to make this go as good as it can?
Thanks, Brandon |
Re: 1987 Nissan Pulsar Clutch
Make sure you machine the flywheel, it will tell you to do that on the instructions that come with the clutch. It would be a lot easier to install a completely new clutch assembly so that you will not need to remove the gearbox again in a hurry. It is pretty simple if just put everything back in the right place and make sure you do all the bolts up TIGHT!
GOOD LUCK |
