Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 07-24-2004, 09:17 PM
ringo7 ringo7 is offline
92 lincoln air ride
Replaced water pump/good the rear struts were all the way up/couldn"t
get the front to raise'compressor runs. I then raised front to level. I now
have all four struts flat/compressor runs will not raise car any techinicians out there?
Old 07-24-2004, 09:20 PM
Re: 92 lincoln air ride
I used soap at the 4 lines at rear of dryer. Some leaking there.Don"t know if this is problem.
Old 07-25-2004, 01:50 AM
slimer68 slimer68 is offline
My advice is don't bother fixing air ride unless you really really want it. It is expensive to fix and yet unreliable. For 500 dollars or so you can replace it all with regular coil over struts that provide just about as smooth a ride with added control. I did this to my 94 about 2 months ago in my driveway. Not a fun job but saved me about 1500 dollars.
Old 08-19-2004, 09:46 AM
Matthew_14 Matthew_14 is offline
Call strutmasters.com. Get the 4 wheel conversion and don't worry about that air suspension again. Only costs about 500 dollars.
Old 08-31-2004, 07:17 PM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
I would not change the air ride if I were you..
you take out the air ride and all you have left is the shell of a lincoln my friend had change his air ride with the coil over struts and sold the car three weeks later he told me that the car does not ride the same and the back end still seats down to low
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
Old 09-01-2004, 09:50 AM
I wouldn't let that scare you away from the conversion kit. As in everything there are pros and cons. The conversion is an upgrade over old worn out air suspension. However, as every lincoln owner knows nothing compares to the ride quality of the air suspension when it is working correctly. To me the tie breaker is the cost of maintenance. The air suspension is over twice the cost of the conversion kit and is still subject to failure later on. If ride quality is your main concern and money is noooo object then stick with the ari suspension. If consistancy and peace of mind is more imprtant not to mention keeping your wallet a little heavier then get the conversion kit. Either way you go it is still an upgrade on old worn out suspension parts.
