Go Back   Automotive Forums Car Chat > Daewoo > Leganza
Old 07-24-2004, 08:01 PM
angylbane angylbane is offline
Angry Gear Shift
Recently, I've been made to put my car key into the Shift Lock in order to get it to shift out of Park. It happens whenever I put the darn thing into Park, whether I've been driving, or I just start up the car.
I'm driving a 2001 Daewoo Leganza. It's still got the warranty on it, but I wanted to know what was wrong with it so I don't get shafted when I take it in. Has anyone else had this problem?
Old 08-28-2004, 04:25 PM
johnplac johnplac is offline
Re: Gear Shift
Have same problem Did you find a solution?
[email protected]
Old 08-28-2004, 04:28 PM
Angry gear shift
Same problem must put in Neutral and use key to unlock before starting. How to disengage this system?
Old 08-28-2004, 05:14 PM
Re: gear shift
Unfortunately, I haven't been able to correct this problem. It's been quite a while now, and nobody seems to have an answer for me. If anyone has any ideas, or where we can get some answers, we'd sure appreciate it.
Old 09-07-2004, 09:45 PM
TMcNutt TMcNutt is offline
Re: Gear Shift
I have a 99 Daewoo Leganza SE and this has happened to me too. It started when my wife told me that it would not get out of park unless you used the key in the shift lock. She continued this for several weeks until we went to a family gathering (in seperate vehicles) then I noticed that the brake lights where not coming when she was stoping. I called a local dealer in Hillsboro to see if they had a brake light switch which was about $13.00 if I recall right. Needless to say after installing the switch I was able to get it out of park without using the key in shift lock.
So you might want to see if you don't have brake lights and if not, go buy the brake light switch. It make life a whole lot easier....
Old 09-14-2004, 06:35 PM
platypus60 platypus60 is offline
Re: Gear Shift
I've had this problem twice with my Daewoo Nubira 2000. The Daewoo brakelight switch is very cheaply made. I suggest buying two and keeping one in the glove compartment for next time. The place I ordered it from said they couldn't keep them in stock, and I could see why after I recieved it.
Be careful before the part is replaced. You have no brakelights! Watch your back, no one can tell when you are slowing down!
I actually purchased a sturdier brand that won't fit, hoping to find someone who would make it fit. No luck, yet. A regular garage won't tinker around with unmatching parts.
Old 10-04-2004, 01:17 PM
Kaedis Kaedis is offline
Where exactly is the breaklight switch located in the 2001 Leganza?
I have both those problems, and I would like to fix it myself.
Thank you.
Old 11-09-2004, 07:56 PM
just follow the brake pedal up and there will be something that looks like a switch. that is it, remove it gently and replace it with the new one.
Done!
1999 Ford Ranger XLT Sport X-Cab.
1994 Ford Explorer XLT 4x4 4dr.
1999 Daewoo Leganza SE 4dr.
1992 Ford Mustang LX Convertible 2.3L
Old 01-01-2005, 07:22 PM
jeremy116 jeremy116 is offline
Send a message via AIM to jeremy116
Hello,
This site and thread has been very helpful! I have had the problem with the shift lock for a while, and just today my brake lights stopped working. The regular lights work, the bulbs are fine as are all of the fuses...but after reading this thread I now know what the problem is.
Does anyone know where I can find this part? I haven't had luck in the past with getting parts for Daewoo. Any help would be appreciated!
PS-I am in Tampa Florida, but if there is somewhere online that would be great too. Thanks!
Jeremy
Old 01-14-2005, 08:32 PM
rexygirl rexygirl is offline
Re: Gear Shift
You can call Daewoo at 1-877-362-1234 and find out where the nearest dealer is to you. I know there is one in Orlando...maybe they will mail it to you.
Old 10-30-2005, 09:16 AM
ililo ililo is offline
Brake light switch installation
Folks,
I have purchased a brake light switch after reading the articles on the forum and noticing that the switch might be the solution to the "not able to sshift out of park" problem on my 2000 leganza.
It is longitudinal, black and has a plunger. 4 copper leads at one end.
I cannot find where to putit in after looking in the brake pedal area (at the upper extremity of the foot pedal).
Can people who have done it provide detailed instructions?
I notice its very difficult to lie down (even withsteerring wheel fully up and seat pushed back) and work in that area. I cannot raisemy wehicle like a mechanic. any tips?
mahesh
[email protected]
Old 10-09-2006, 05:21 PM
keitort keitort is offline
Re: Gear Shift
had same problem with my 2000 Leganza. Brake light switch fixed problem. Can be purchased thru Auto Zone either online or at store. Either way takes about 2 days to recieve. wires just plug back into piece and unit needs about 1/2 turn to lock into position on bracket on brake pedal
Old 07-23-2008, 02:15 PM
novall novall is offline
Re: Gear Shift
After Reading Your Solutins I Located The Brake Switch Next To The Brake Pedal (very Dificult To Get To It) I Follow The Advice Of Trace The Cables And Found They Were Toching A Metal Frame, Moved Away From The Metal, Mover The Switch Arround Back And Fowred Acople Of Times And Bingo It Work, No Parts To Replace And No Trips To The Mecanic. Be Patient It Is Hard To Get To The Brake Pedal .
