Old 07-24-2004, 04:39 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
Finished brake job, but one problem
My brake pedal gets stuck if i push it all the way, and when i push it in a little bit it slowly comes back to the default postion... I don't want to drive it like this so i don't knowwhat happens on the road, but if my car is on and I push the pedal... it comes back up really slow...
what did I do wrong?
Travis
Old 07-24-2004, 10:26 PM
ZCrazyman ZCrazyman is offline
Re: Finished brake job, but one problem
how did u blead the brakes did u bleed them like the book says??
4th gen Civic... is there a better car to own??
My Ebay Items for sale: and more to come... CHECK THEM OUT!!!
http://cgi6.ebay.com/ebaymotors/ws/e...sort=3&rows=50
Old 07-25-2004, 10:56 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
air in the brakes still... bleed them more
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 07-25-2004, 11:09 AM
Onimacus's Avatar
I used a C clamp to bleed them.
Travis
Old 07-25-2004, 11:50 AM
91hbman 91hbman is offline
Send a message via Yahoo to 91hbman
you need to bleed them at the bleeder valves, get some one to pump up the brake pedal, then open the valve to release the air in the line helps to put a small hose on the valve and run it into a jar of brake fluid, that way when the air bubbles stop coming out you'll know your done. keeps from air getting back in the line also. do that for each wheel
Thanks for any of the help that anybody has offered. I try to do the same. And remember "It takes all kinds to make the world go round."
Old 07-25-2004, 01:27 PM
crx91's Avatar
crx91 crx91 is offline
the clamps are to push the piston so the pads fit in.there is a blled screw at the calliper and drums.you need another person to help you out.look at the helms manual and it will tell you the correct procedure on bleeding your brakes.i think its front passenger to driver rear and then passenger rear to front driver.have the person that helps you out to pump your brakes six times and at the sixth one to hold the pedal down to the floor,at this time you loosent the bleeder to release the air.if nop fluid comes out then repeat untilk it shoots pure fluid out.repeat to all sides.before you begin remember to brake the nut free then tighten it back up but not to tight so that you dont have a hard time.
