Old 07-24-2004, 03:41 PM
5aclockshadow 5aclockshadow is offline
Send a message via ICQ to 5aclockshadow Send a message via AIM to 5aclockshadow
How to replace rear shocks on 95 LeSabre???
Looks like we can't get to the top of the rear shocks because the rear deck is covering the opening.
Any tips on how to replace the rear shocks???
Thanks.
Old 07-24-2004, 06:07 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: How to replace rear shocks on 95 LeSabre???
pull the paneling off from inside the trunk, you should be able to access the bolts from there.
Old 07-24-2004, 07:12 PM
Jed Rule Jed Rule is offline
You can also remove the rear seat back.
Old 07-24-2004, 09:18 PM
Re: Re: How to replace rear shocks on 95 LeSabre???
We tried both entry from the trunk and removing the back seat. We could not get a wrenh on the center nut for the shock. What size is it? Does it require a special tool?
Old 07-25-2004, 12:07 AM
tman's Avatar
Pimpin' ain't easy
I can't imagine it being anything other than a normal metric socket.
Old 07-31-2004, 09:31 AM
David1966 David1966 is offline
Hi,
You may have already figured this out, but I replaced the rear struts on a 94 Lesabre yesterday. One of the mounting nuts you can get to from the trunk, but we had to remove the rear seat in order to get to two access holes in the rear deck for the other two nuts. You have to remove the strut mount along with the strut and transfer the old strut mount off the car(assuming it's still in good condition) to the new strut. Then you put the whole assembly back in. This was definitely a two person job for the amateur mechanic.
Also, watch out for razor sharp metal edges in the trunk!!!
I used KYB struts, which ride MUCH better than the originals. Of course, the originals were shot, but I think the KYBs are probably much stiffer.
David
