Old 07-24-2004, 01:54 PM
budman budman is offline
head rebuilt, now car will not start
I am having a serious problem, its on my 90 eclipse 2.0t. I had the head rebuilt my well known shop in my area, we put everything back together and the car will not start, but it does crank. The crank, and oil sprockets were lined up correctly, as well as the cams. We have spark,fuel, and touble checked the timing with a light and everything is good. We both had looked over everything numberios times with no luck. Any thoughts would be greatly appreciated. I am new to the DSM scene.........THanks
Old 07-24-2004, 03:12 PM
10.5sec92AWDTALON 10.5sec92AWDTALON is offline
Re: head rebuilt, now car will not start
More often than not even when folks think they have everything timed right on the timing belt, they don't. Find someone else that knows about cars to double check all your sprocket alignments.
Old 07-24-2004, 10:04 PM
Thanks the timing was double checked even after the timing light read it was good, it was slightly off. Now its good to go...... THanks again
Old 07-24-2004, 11:18 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
lol u make it sould like we have a DSM night club/rave going on here ,but personally i think its time for kevin to get in here and anlyse ,concur, and to slove the problem and give u the solution...........money back gaurentee!
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 07-25-2004, 07:14 AM
kjewer1 kjewer1 is offline
AF - Advisor
First posibility to eliminate is the cams being 180 degrees off. There are marks on both sides of each cam gear, did you make sure the dowel pin that aligns the gear to the cam was at 12 oclock? Secondly, have you done a compression test.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
