Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 07-24-2004, 12:34 PM
PURPLEPILL 2005 PURPLEPILL 2005 is offline
88 ford aerostar
had a problem with starting/stalling changed out ign. coil,pick-up,module,plugs,wires,cap,rotor. still having same issue, i suspect the fuel pump, but did a fuel pressure test and it was fine, but may be an intermittant issue w/ pump, will drop tank anyway, because it has aleak in it at the top. everytime i fillup the gas leaks out from the top. also could be electricalconnections are worn as well. will let u know how it came out.
purplepill in fl.
Old 07-25-2004, 08:44 AM
Car Pal Car Pal is offline
Re: 88 ford aerostar
is it a 4 liter? iac valve could be stuck.
