Old 07-24-2004, 10:40 AM
jeepthing5280 jeepthing5280 is offline
Angry 89 cherokee not starting
Ok, Just replaced the engine in my 89 cherokee with a good used one. Has a new head and all new gaskets. Engine turns over fast and then bogs down for a second. Getting spark to plugs but no fire. getting fuel to fuel rail. i've tried messing with crank position sensor and now im out of ideas. Any HELP
Old 07-24-2004, 11:58 AM
georgedexter georgedexter is offline
Re: 89 cherokee not starting
Messing with CPS? That ain't the same as changing cps. Try this website;
http://www.lunghd.com/Tech_Articles/...iagnostics.htm
You may find an anwser.
Old 07-24-2004, 02:45 PM
ok, here goes.... engine was turning fast then bogging down or trying to fire out of order. If i unplug the cps, the engine turns nice and free.?????????????? What exactly does the cps do? why am i getting spark at the spark plugs (and fuel) but no fire? im lost
Old 12-09-2004, 09:12 AM
rlrobian rlrobian is offline
Assuming you've removed the Dis cap and spark plug wires, you may want to recheck the firing order.
Old 12-09-2004, 12:07 PM
Dale Aeppli Dale Aeppli is offline
Sounds ike you have distributor or plug wires crossed Did you have distributor out. Check firing order. If you remove cps you aren't going to get spark it creates the spark Dale [email protected]
questions give holler
Old 12-09-2004, 12:12 PM
89ltd 89ltd is offline
did you replace the timing chain?
