Go Back   Automotive Forums Car Chat > Ford > Contour
Old 07-23-2004, 11:35 PM
dghawk dghawk is offline
96 Contour - idle fluctuates with a/c on...
Help!! I have a 96 Contour - Zetec 4 cylinder. If I let the car idle, in gear (AT), with the a/c on, the idle fluctuates badly, almost stalling the engine. If I turn the a/c off, it quits. Don't see any vacuum leaks and no CEL. Any ideas?? Thanks in advance for your discussion. Sincerely, Dave.
Old 07-25-2004, 06:46 AM
Car Pal Car Pal is offline
Re: 96 Contour - idle fluctuates with a/c on...
the refrigerant could be low. the processor anticipates the compressor to come on and raises the idle. if it doesn't, it drops back down. check to see if the compressor is coming on and staying on. if it cycles on and off rapidly there is not enough freon'usually from a leak.
Old 07-27-2004, 11:32 PM
Thanks, Car Pal!! That's exactly what it was!! I appreciate your help!! Sincerely, Dave.
