Old 07-23-2004, 10:19 PM
CR50HC CR50HC is offline
Clutched replaced, reverse now grinding, can't get into gears!
Hi folks. I just had my clutch replaced in my 89 CRX DX. Now, I ca't seem to get the car into 1st gear without "forcing" it. The car also severely grinds when you try to put it into reverse. After getting the car going, it shifts into 2nd but it's hard to get it there, third is a little easier, 4th is hard to get into, finaly 5th is easy to get into. What is going on with my daily driver and can it be fixed?
Troy
Old 07-23-2004, 11:50 PM
QuikShifter's Avatar
QuikShifter QuikShifter is offline
Re: Clutched replaced, reverse now grinding, can't get into gears!
check your tranny fluid. prolly forgot to refill it. Almost sure thats your problem.
Old 07-24-2004, 12:55 AM
Hybrid1990crx's Avatar
Did you take the frist couple thousand miles easy? When you replace a clutch you shouldn't be hard on it for like 3,000 miles.
Old 07-24-2004, 01:55 AM
RedRex16 RedRex16 is offline
Send a message via AIM to RedRex16
my tranny is kinda hard to get into gear too and it grinds in reverse. do you think i should change my fluid of is my trany just plain old. lol
Old 07-24-2004, 03:02 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
You guy need to adjust your tranny cable out more. thats all that is wrong. Ok Ill kinda explain. It the cluch disk is too close to the flywheel it will try to spin the tranny if your in neutral then it is spinning everything inside but not in gear. Then you try to put it in gear the shaft is spinning inside the tranny and it has to slow down so you can put it in gear. Thats your first gear problem. As far a reverse goes there are no syncros in reverse so nothing to try and slow the speed on the main shaft to engage so it grinds. So just adjust your cable out about 2-3 turns and you will not have this problem anymore.
Oh forgot also if you messed up the pilot bearing like not putting a little grease on it when it went back in, then this could also effect it but not likey cause you guys know better than to put a dry pilot bearing in right?
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 07-24-2004, 06:13 PM
Re: Re: Clutched replaced, reverse now grinding, can't get into gears!
this is also true !! basically adjust it till you can engage all gears smoothly while the engine is running. I guess if thats not your problem, then your pilot bearing could be dried & fried!
Old 07-24-2004, 07:26 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
That same thing happened to me, when I first got my car I had to replace the clutch and when I was done and went to take it for a test drive it wouldnt shift into gear (i was bummed) so I just backed the adjuster off a few turns and it ran great.
Old 07-24-2004, 08:26 PM
Thanks folks. You are describing my problem perfectly. I will adjust the clutch cable and hope for the best. My local shop did the work so I'll have to ask them about the pilot bearing. My mechanic replaced the tranny oil so, I don't think that could be the problem. I'll let you know how it turns out.... I sure do misss my REX. Been 5 days without......
Old 07-25-2004, 07:03 PM
krustindumm's Avatar
krustindumm krustindumm is offline
im 99% sure your clutch cable is too loose. adjust it for ~5mm play in the pedal.
91 Civic Dx Hatch
Midwest Honda's MySpace group
Old 07-25-2004, 09:51 PM
I just talked to my shop and my mechanic says the tranny oil is full and that he lubed the pilot bearing before repacing it. I'll metion the 5mm of play on the cable adjustment. Hoping to get my Rex back soon. Driving my Tacoma Double cab is getting pricely gas wise.
Old 07-26-2004, 08:42 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Hahaha... that is not necessary nor have anything to do with it. The cable probably just needed adjusting...
The shop that replaced my clutch (did my tranny 2k miles later) said I needed at least an inch of play in my clutch pedal (note: they work only on hondas... called "especially honda" ;-) and I thought they were totally high or something. It just felt weird... so I just turned the clutch cable adjuster a couple of notches and voila... perfect!
just my
2008 KIA Spectra5 SX
2010 Honda CR-V EX
