Old 07-23-2004, 08:51 PM
cagrote cagrote is offline
2000 Windstar PCV valve location
I've read the previous posts regarding the various locations of the PCV valve on models '96-'99. Is the 2000 the same as the '99?
Old 07-24-2004, 06:05 AM
sahib sahib is offline
Re: 2000 Windstar PCV valve location
My Haynes manual doesn't say anything about it being anywhere different than the others. It should be on the rear valve cover toward the right (passenger) side of the engine.
Old 07-24-2004, 09:46 PM
wesley841 wesley841 is offline
pvc location
The location of the pvc valve on the 3.8 ltr is on top of the rear valve cover. I don't know were the pvc valve is on the 3.0 ltr. If you need to change it .On the 3.8ltr start by removing the air filter housing and the flexable tubing ,you might be able to see it on the back valve cover tords the throttlebody side. Good luck.
Old 07-25-2004, 07:53 AM
Car Pal Car Pal is offline
its in the front,under the rubber grommet.
