Old 07-23-2004, 08:48 PM
steve11 steve11 is offline
lost ignition key!
kids have a 92 we use for a utility vehicle around the farm. lost the ignition key. considering drilling out the center with a 1/4 inch carbide bit, picking out the pieces and jusst using it as an on off switch. anyone removed the ignition lock before? does it sound like this would work? if i pull the lock barrel out will i be able to just rotate the outer part?
Old 07-24-2004, 10:28 AM
marchi1's Avatar
marchi1 marchi1 is offline
Send a message via MSN to marchi1 Send a message via Yahoo to marchi1
If you take the vin to the dealership they can cut you a new key as long as you haven't changed the cylinder before.
2004 Sunburst Orange Metallic Cavalier
not stock, but not done yet either.
Old 07-24-2004, 07:06 PM
public's Avatar
public public is offline
Re: lost ignition key!
Your solution will work on this car. Car theives use a slide hammer to pull the lock cylinder out and then you can start it with a screwdriver.
