Old 07-23-2004, 08:17 PM
a_hol06 a_hol06 is offline
Send a message via Yahoo to a_hol06
4ch amp, maybe profile?
I am looking for a 4ch amp to power aftermarket speakers, which i havent bought yet and am still pondering over. id like the amp to give anywhere from 35rms to 60 rms at 4 ohms.thought about getting a profile ca440, is that amp good? if not let me know of some good models. Dont have to be high-end, just good value.or would it be just the same at that power to keep stock speakers and amp them?
Old 07-24-2004, 12:20 AM
fender5's Avatar
fender5 fender5 is offline
Send a message via AIM to fender5
Dont keep stock speakers and amp them.... If ur gonna amp them up u need to get new speakers and wires
Old 07-24-2004, 04:54 AM
KMoney28 KMoney28 is offline
Send a message via AIM to KMoney28
If you do get a 4 channel amp, go with a little more power. I put a 300 watt Pioneer on my aftermarkets and the difference was unnoticeable. It basically puts out the wattage of an aftermarket deck but with a bit more clarity. If you really wanna hear your vocals loud and clear increase the RMS a bit.
Old 07-24-2004, 08:34 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: 4ch amp, maybe profile?
You will want about 100 rms to each speaker if you are running 2. If you are running 4 50rms for each speaker should be fine. If you run comps you wouldn't notice much difference from headunit. If you run coaxs it should do way better. NO offense Kmoney28, but using the pioneer as an amp is a bad example. Those amps suck at putting out their rated power.
www.cloudcity.deviantart.com
