Old 07-23-2004, 07:50 PM
KPVSR KPVSR is offline
Removing Inner Door Panel '98
Some how my outdoor handle cracked so I need to replace it. I have a new one but before I start breaking things from not knowing what I am doing how does one go about removing the inner door panel to gain access to the inside?
Old 08-24-2004, 10:44 PM
gwkchevy gwkchevy is offline
Re: Removing Inner Door Panel '98
start with removing the bezel around the inside door handle (pry gently) and then the electric control pad slides out of the panel (power win switch). The panel either slides up or will pry off (if won't slide up, then use a screw driver to pry the panel apart from the door. Start at the bottom and work your way up.) I use an actual pry tool which has a notch that will slide over the button. The buttons just have teeth.
