Old 07-23-2004, 07:42 PM
Dr Juice Dr Juice is offline
Send a message via AIM to Dr Juice Send a message via MSN to Dr Juice
Broken Amp?
Um, ya, i started listening to my music on thurday afternoon, and then im headed over my buddys house friday night, and my amp dont turn on. Its a JBL p180.2. The red light comes one, then the green comes on, and then fades off and the red light comes back on. Checked fuses and connections, all fine, the amp was pritty hot, could it be over hearting?
Old 07-23-2004, 09:09 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
Does the amp run after it cools?
Old 07-23-2004, 09:52 PM
Navy I.C.'s Avatar
Navy I.C. Navy I.C. is offline
Re: Broken Amp?
that red light is probably a protection ckt. What is it protection from?
THE DARKNESS!!!
an African Soup Bone Production...
Old 03-29-2005, 08:12 PM
jt 71x jt 71x is offline
Re: Broken Amp?
i have a proble like that too. i was in my car and my subs were on and then they just shut off and i looked at the amp and the power light was on but the protection light wasent. i checked all the fuses and conections to and there was nothing wrong.
Old 03-29-2005, 08:14 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Broken Amp?
do you have a multimeter?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-29-2005, 08:22 PM
Re: Broken Amp?
me or dr juice
Old 03-31-2005, 11:00 AM
mysatilac's Avatar
mysatilac mysatilac is offline
anyone with a system probelm should get a multimeter and check for battery voltage going to the amp, most problems with amps are because of wiring,
even if you checked both ends (connections) of the cables, in a truck I fixed recently with a similar problem. there was a crimp type butt connector for the remote wire that deteriorated under the carpet, and caused the system to periodically turn on/off
Do you have a power (red) light without the remote wire connected? (green = on) (red = power)
Do you have another working amp you can jumper the remote wire from? (this is how I found the problem on the Truck)
It's beautifully destructive isn't it,
'97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing...
Old 03-31-2005, 11:48 AM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: Broken Amp?
if it was pretty hot the amp was overheating and could have caused damage
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 03-31-2005, 11:57 AM
mysatilac's Avatar
Re: Broken Amp?
"pretty hot" is a relative term, amps get real warm, but shouldn't get hot enough to burn you or anything... Yes, overheating can cause permenant damage, but you should at least test it before buying a new one!
Old 03-31-2005, 03:46 PM
sr20de4evr's Avatar
Re: Re: Broken Amp?
Originally Posted by jt 71x
me or dr juice
considering the rest of this thread is almost a year old, you
'01 Black Sentra SE
'05 Silver WRX STi
Old 03-31-2005, 10:39 PM
Re: Broken Amp?
no i dont think so what is it? im new at this stuff, sorry
thanks for your advice and what does a multimeter do. wher can i get one.
Old 03-31-2005, 11:48 PM
sr20de4evr's Avatar
Re: Broken Amp?
you can find them at hardware stores
you can use them check to make sure the sub isn't blown, the amp is getting power, the amp is getting a signal, the amp is putting out a signal, etc.
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-03-2005, 01:33 AM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: Broken Amp?
It sound like your amp. The reason is b/c your subs are prob 2ohm and when you have them bridged together they create 1ohm. 95% of amps aren't 1ohm stable and you can be just damaging your amp, if its not already.
Old 04-05-2005, 11:37 PM
Re: Broken Amp?
ya i got new rca conections and it still dint do anything. im so mad. also i didnt have my speakers hooked up yet but i was just listening to my subs, i dont know if not having my 6x9's hooked up had anything to do with it tho. it seams like it is not getting any signal from the cd player but im gona try hooking my amp up to one of my friends system so ill know then if its shot or not. but is thier anything else that could be wrong?
Old 04-08-2005, 11:41 AM
bostwickdcl24 bostwickdcl24 is offline
Re: Broken Amp?
it seems as if i would have to agree with shawn if you ran them in series parrelell then that should fix the problem
