Old 07-23-2004, 07:17 PM
warfox69 warfox69 is offline
Question Stiff/Sticky gas peddle
I own a 2001 chev silv extended cab. When I have the engine off the gas peddle moves freely and smothly, when I have the engin on and push on the peddle it gives alot of resistance, i will aply presure on the peddle but the peddle does not move, then i apply more pressure and the peddle snaps forward causeing the truck to acelerate abruptly. I have tryed lubricateing the pivot points on the gas peddle inside the cab but it does not do anything. If anyone has any sugestions please let me know, anything to hopefuly get this fixed on my own insted of bringing it to the auto shop and getting riped off.
Thanks to anyone who responds.
Old 07-23-2004, 07:52 PM
mjgjr72 mjgjr72 is offline
try cleaning the throttlebody
Click To See My Ride 2000 Chevy Silverado LT Z71 K1500 ecsb, 6" suspention lift, 4.56 gaers, 315/75r16 bfg mt, radix supercharger, gibson headers and cat back, trasgo shift kit, aluminum servos, nelson tune
Old 07-23-2004, 08:20 PM
tidalcock tidalcock is offline
Yep, gotta clean that throttle body with some carb/choke cleaner. May have to do it more than once. Should make a noticeable difference.
Old 07-26-2004, 06:01 PM
rustcal rustcal is offline
Send a message via AIM to rustcal Send a message via Yahoo to rustcal
don't use carb cleaner. use throttle body cleaner. I was told by a tech that sea foam works real good to for cleaning the throttle body. He said not to use carb cleaner cuz it has chemicals in it that could harm the throttle body. My local dealer say he would clean it for $100. I told him he should replace it for free cuz there is a tech bulletin out for this problem. If your truck is under warranty they replace the throttle body for free.
Old 07-27-2004, 05:31 PM
Puffnstuff's Avatar
Puffnstuff Puffnstuff is offline
Send a message via ICQ to Puffnstuff
Re: Stiff/Sticky gas peddle
This problem started with the 99 model year ls1 based engines and I happened to have it. I used b12 chemtool on it to clean the tb bore and where the butterfly pivots. The dealer did replace it per the tsb however the new part still did the same thing after a few months so I just periodically cleaned it when I felt it start to stick again.
06 Toyota Tundra Double Cab
Old 07-28-2004, 10:09 PM
Cool thanks for the input guys, ill try cleaning the TB and see if that helps, Ill let yah guys know if it worked. Thanks again.
Old 07-30-2004, 05:51 PM
HighMiles-LowRide HighMiles-LowRide is offline
Here's one for all you Hi mileage owners! The TBI throttle shaft will actually wear down and allow the butterfly to settle too far into the throat. This causes serious binding (sticking) which also is worse when the engine is running and vacuum is on it. My 312,000 mile 91 has had this problem for 200,000 miles : )
Old 08-08-2004, 01:26 PM
rl1inpa rl1inpa is offline
Send a message via AIM to rl1inpa
Talking sticky gas peddle
I have a 99 Silverado with the 5.3 and I had the same sticky throttle problem. Thanks to this site I was able to resolve this issue with some throttle body cleaner. Easy fix to a very annoying problem. Thanks for the tip.
Old 08-08-2004, 09:14 PM
Talking It worked!
Cleaning the TB fixed the problem for me. Thanks for the help guys; your awsome. Good to have a way of talking with people who realy know their shit. I have also installed a K&N FIPK G2 air intake, i love it!
Old 08-19-2004, 10:18 AM
dclonch1 dclonch1 is offline
Just read about this on this forum. Mine has been sticky since I got it - about 6 months now. Last night I went and got some TB cleaner (O'Reilly brand) and used a rag and a nylon brush and cleaned the TB well. It is now like new - smooth gas! Thanks.
