Old 07-23-2004, 07:13 PM
Hybrid1990crx's Avatar
Help me seperate my tranny!
Ok, so I'm trying to fix my LS tranny, it has a broken shifter fork. So I am trying to seperate the gear housing from the bell....if thats what you call it. I got it kinda seperated, I have a 1 inch gap all the way around. But it seems to be stuck on something. So I decided to stop before I fucked something up even worse. I think the tranny may be in gear...first gear, would this be causing the problem? I raelly want to fix this! So thanks to anyone who helps me out.
Old 07-24-2004, 10:12 AM
Re: Help me seperate my tranny!
Bump. I'm just going to keep doing this until I get some help.
Old 07-24-2004, 05:14 PM
Come on guys, someone has to know!
Old 07-25-2004, 02:02 PM
bump. i know someone knows...
Old 07-25-2004, 04:17 PM
stickershop's Avatar
stickershop stickershop is offline
There's usually a plug at the end of the tranny that you have to remove. Underneath it, there is a spring clip that holds the tranny case onto the main shaft. You need to open the spring clip a bit so that it will release the case from the tranny.
StickerShop.ca - got stickers?
High Quality Custom Vinyl Graphics, Signs, and Banners :thumbup:
Proud owner of two 1991½ Honda CRX Si Special Edition's (sequential VINs too!)
Old 07-26-2004, 09:49 AM
dagoEF's Avatar
dagoEF dagoEF is offline
Try here this helped me when I swapped my tranny
http://www.carenthusiast.com/crxuk/C...hop_Manual.pdf
Old 07-26-2004, 10:02 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: Re: Help me seperate my tranny!
yeah thats your problem and make sure you spead it open when dropping the case back on... learned that the hard way...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
