Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-23-2004, 04:12 PM
gx45650 gx45650 is offline
Send a message via Yahoo to gx45650
P1320 warning light code on. Anyone know what this means?
I have a 2000 Infinity I30. My warning light is on and I took my car to Auto Zone. They hooked up their dianostice computer and it said P1320, Manufacturer Control Initition Sysem or Misfire.
Anyone have any idea what this means? I appreciate any responses. Also anyone know where I can get a service manual on my car for a cheap price?
sincerely,
Steve
Old 10-18-2004, 03:37 PM
bertblank bertblank is offline
Re: P1320 warning light code on. Anyone know what this means?
sincerely,
Steve
Hey Steve,
I have a 1999 Nissan Maxima and had the same problem. I was too cheap to bring it in to the dealer because they wanted to charge me $125 just to scan the darn thing. Instead I bought a scanner from Kragen and scanned the thing myself. To make a short story long, I had several codes at 60,000 miles. I had a P1320, P300, P304, and I think it was a P325. The P300 and P304 are misfires. The P325 is a knock sensor code. I changed the spark plugs and got rid of the P325 code but still had the P1320 and P300. I finally tracked it down to a faulty ignition coil. You can test these by using a volt meter to test the resistance. To do this you should look it up in a Chilton type manual. Let me know if you have any other questions. Good luck.
Bert
Old 10-19-2004, 08:51 PM
maxi_kitty123 maxi_kitty123 is offline
What kind of scanner did you brought from Kragen? How much was it? Which brand?
My 95 maxima (120,000k) is having some problem now, rmp needle got stuck, funny oil leak under the driver seat (yes, interior oil leak?!)... Minor, but annoying little things.... Would a scanner help to find out what's happening?
Old 10-20-2004, 03:21 AM
VQmax95's Avatar
VQmax95 VQmax95 is offline
Send a message via Yahoo to VQmax95
you can pull the codes yourself....there is a diagnostic screw on the ECU
Old 10-20-2004, 03:25 AM
VQmax95's Avatar
here is a link that tells you how to do it. http://forums.maxima.org/showthread.php?t=104931
