Old 07-23-2004, 03:06 PM
Charmm Charmm is offline
decisions decisions....
i am now completely certain that i am getting a audiobahn a8000t amplifier. at 2ohms it will be running at 800 watts and at 4ohms 400watts. in order to get 800 watts to two subwoofers, would i have to get 2 subs with 2ohm load, 2 subs with a 4ohm load, 2 subs with dual 2ohm voice coils, or 2 subs with dual 4ohm voice coils? and also how would i get 400 watts at 4 ohms(same questions)? wow thats alot of questions gimmy feedback. thanx.
charmm
Old 07-23-2004, 07:12 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: decisions decisions....
To run the amp at 2ohm, you would simply need the final impedence of the sub setup to be 2ohm. You can do this with 2 SVC 4ohm subs, or 2 DVC 2ohm subs.
To run the amp at 4ohm it's the same deal, but you would need 2 SVC 2ohm subs, or 2 DVC 4ohm subs.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 07-24-2004, 03:22 PM
Thats really interesting. so if i get 2 dvc 4ohm subs the amp will give both of my subs 400watts.
is this enough for the alpine type s im looking at that is 300w rms 900w max dvc 4ohm? or should i get the same type s with 300w rms 900w max dvc 2ohm giving both my subs 800watts?
hit me back
charmm
Old 07-24-2004, 03:34 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
You sir are confused...
When you get 2 dvc 2ohm subs, you will wire them in series parallel yielding a 2 ohm load, which splits to each sub giving them an equal division of the watts, so 400 to each sub. When you wire it with 2 dvc 4ohm subs, you get a final load of 4ohms yiedling 200 watts to each speaker. Get DVC 2ohm subs.
www.cloudcity.deviantart.com
Old 07-24-2004, 03:46 PM
okay that makes more sense now haha. i am also making my own box and it has .9 cubic feet of space per side. how could i add a port to this box, or do i have too little room.
thanx
Charmm
Old 07-24-2004, 04:27 PM
Haibane's Avatar
Let me look into that for you...
Old 07-24-2004, 04:28 PM
Haibane's Avatar
What size sub(s) and how many? What type also?
Old 07-24-2004, 08:42 PM
Well, right now im getting 2 12" subs (Alpine Type-S DVC 2ohm like you suggested) and im building a box at the moment. The box is going to be...
Height - 13.5"
Length - 35"
Bottom Depth - 14"
Top Depth - 7"
The side will look something like....
............._______
...../__________.|
(Ignore the periods hahahah)
The Subs will be on the flat part.
I figured out the inside cubic feet with 3/4" MDF to be ~.91 Cubic Feet for each side of the sub because it will be divided into 2 parts.
the recommended cubic feet for a sealed box is .85 to 1.5 Cubic Feet
The recommended for a Ported box is 1.24 2.0 cubic feet
this is all the space that i have to spare but i was wondereng if there were tricks to make it bigger. (I heard of poly fill but i dont know anything about it or how it would affect my box size or where to get it)
hit me back
Charmm
Old 07-24-2004, 09:01 PM
Navy I.C.'s Avatar
Navy I.C. Navy I.C. is offline
since your box is too small for a port, you should get a passive radiator. that's basically a speaker without a motor assembly. so what you'll appear to have is 4 subs, but only two of them will be active and the other two works off of the pressure of the energized subs. tuning them is just a matter of adding weights.
THE DARKNESS!!!
an African Soup Bone Production...
Old 07-24-2004, 10:46 PM
where could i get something like that? and also could i just put it on the top of the box? how big dose it have to be?
im interested in this passive radiator
hit me back
Charmm
Old 07-24-2004, 11:34 PM
Haibane's Avatar
I wouldn't go with a passive radiator, but you can get one at adireaudio.com
Old 07-25-2004, 01:32 AM
what would you suggest then? just keep it in a sealed enclosure?
Old 07-25-2004, 07:03 AM
Haibane's Avatar
I would keep it sealed. Passive radiators are not very accurate
Old 07-27-2004, 02:39 PM
Haibane's Avatar
2.632 total cubic feet
1 Top, 1 Bottom: 11.74 (c) x 18.07 (b) in
0.75 (thick) in
1 Front, 1 Back: 26.81 (a) x 16.57 (d) in
0.75 (thick) in
2 Sides: 26.81 (a) x 11.74 (c) x 0.75 (thick) in
