Old 07-23-2004, 01:33 PM
g00eY's Avatar
g00eY g00eY is offline
bodykits
im planning on getting either an integra and making a widebody kit for it... this will be my first attempt at bodykit making so i have a few questions. and yes i did look in the faq and how-to.
1. should i/do i have to use styrene?
2. what kind of putty should i use? im confused on which one to use for making bodykits.
3. how do i make the big vents that go behind the wheels on a widebody kit? do i use styrene?
Old 07-23-2004, 03:21 PM
geofroley geofroley is offline
Send a message via AIM to geofroley
Styrene is reccomended, but not necassary. You won't use as much putty if you use styrene. Since you're doing a wide body kit, you'll need to bend the styrene to adapt to the shape of the wells. Heat it up a little with a candle or lighter. Epoxy putty is best for bodykitting, especially for widebody. It's alot easier to shape then regular putty. As for the vents, I don't know how to make them.
Old 07-23-2004, 03:25 PM
g00eY's Avatar
Re: bodykits
thanks geofroley
i already have a sketch drawn of the integra. i can try to post it but it really bad cuz i drew it in like 5 minutes and most of the time when i try to add pictures it doesnt work.
Old 07-23-2004, 03:26 PM
Vric's Avatar
Vric Vric is offline
Re: bodykits
there is no need to heat the styrene ! use .15 or .20 styrene and it will be fine
do a search, all those question were answered before. But styrene is a mush have thing if you want to scratchbuilt body kit
Re: Re: bodykits
Originally Posted by g00eY
thanks geofroley
Anytime Try and get the pics up, I'd like to see it.
Old 07-23-2004, 03:47 PM
g00eY's Avatar
Re: bodykits
does anyone know how to make the pics smaller? the pic is over a megabyte.
Old 07-23-2004, 03:48 PM
Vric's Avatar
Re: bodykits
use a photo editor like Paintshop or Photoshop (or anything that come with your digital camera)
Old 07-23-2004, 04:01 PM
g00eY's Avatar
Re: bodykits
here u go... once again it is a horrible drawing... i rushed through it cuz i was supposed to go mow the lawn.
its really messed up. its got all that stuff all over it and i dunno what that is... probably cuz its my first time messing around with a picture that i loaded onto my computer and i didnt kno what i was doing... but u get the point.
Old 07-23-2004, 04:18 PM
g00eY's Avatar
Re: bodykits
ok... lemme get this straight. i buy some styrene and epoxy putty, i bend the styrene into the shape i want, glue it onto the model, dunk some putty on it, smooth it out, let it dry, and sand?
Old 07-23-2004, 04:20 PM
Vric's Avatar
Re: bodykits
you get the point.. this is how it work
be sure your styrene shame is very stable, or the putty could crack. Wait for few hours for the styrene to glue
Old 07-23-2004, 04:27 PM
g00eY's Avatar
Re: bodykits
asdfasdf i cant wait to get supplies...
Old 07-23-2004, 04:35 PM
Vric's Avatar
Re: bodykits
if you want to look, I still have progress picture from my S2000 that has styrene and putty work:
http://files.automotiveforums.com/ga...p?ppuser=29611
you should understand how it work (they are in order, from 1 to 20)
Old 07-23-2004, 06:32 PM
g00eY's Avatar
Re: bodykits
thanks Vric
Old 07-23-2004, 07:45 PM
Re: Re: bodykits
Pretty much. Depending on what putty you use, you should wait 12-16 hours for it to dry. If it's quick type you only have to wait 6 hours. When you sand it, use somewhere around 400 or so grit.
Old 07-23-2004, 07:53 PM
Vric's Avatar
Re: Re: Re: bodykits
not that much !! Just work with thin layer and you have a drying time of about 1 hour. FOr final sanding, wait 1 day
