Old 07-23-2004, 12:12 PM
speedphreak speedphreak is offline
lower tamiya wrx
how do you lower the wrx from tamiya? I must know! And also I have styrene to cut to make a cover to make it look like a 2 seater. Anyone have tips on how to do both of these, i appreciate it!
-Chris
Old 07-23-2004, 01:36 PM
jberry3 jberry3 is offline
Cut parts of chassis as shown in pictures 1 and 2. This will allow the steel bar to be raised higher into the car . You don’t need to do this to the front as it can be highered without modification. After this is done then take off the brake discs (if already glued on) .You will see that there is a circle with a notch in it this needs to be sanded completely flat . Then re apply the brake discs but about a third of the way up the disc mount area from where originally was.
Hope this helps. Just PM me if you want to ask any questions.
Old 07-23-2004, 01:52 PM
tetsuyagarage tetsuyagarage is offline
Re: lower tamiya wrx
wow good tutorial..lots of work but good none the less... i just take the lazy way out and sit the chassis above the body mounts
