Old 07-23-2004, 11:34 AM
cheezmunky cheezmunky is offline
performance shift problems
I recently had a problem with the light underneath the shifter (the one that lights up p, r, n, d, ...) going off and on so I took center console apart and found that the wire had broken. After fixing that and putting everything back together, the performance shift doesn't work. The light doesn't even come on in the dash when I press the button. Any ideas on what I did or what is wrong? Thanks
1998 gtp - 111,000 mi
Old 07-23-2004, 06:02 PM
justinarm justinarm is offline
Re: performance shift problems
You never reconnected the performance shift wire that goes to the switch, or there is a bad connection in the console. that is probably it.
Old 07-23-2004, 11:21 PM
MoshimoGTP's Avatar
MoshimoGTP MoshimoGTP is offline
Send a message via MSN to MoshimoGTP
The performance shift button activates some sensor on the tranny????, or how it works? can someone explain me please, i need to...
thanks
RED 1999 Grand Am GT - RAM AIR V6 H.O., 4drs, sunroof, and more!
Old 07-24-2004, 12:14 AM
94sportsedan 94sportsedan is offline
not to sure about this but I think it jsut grounds a signal from the pcm, which then makes the pcm change the transmissions table values.
Old 07-24-2004, 11:55 AM
Melvyn_with_a_GTP Melvyn_with_a_GTP is offline
my performance shift button went out on my 97 grand prix. The wire had disconected from the button which just completes a circuit when pressed. The wire had just come unsottered. I wound up just extending the wire to a hidden toggle switch. I know thats a little ghetto but it worked and i no longer accidentaly press the button with my knee.
Old 07-24-2004, 03:48 PM
sure enough, the wire had become unsoldered so I just soldered it back and it works fine. Thanks for the help.
Old 07-25-2004, 04:18 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
The performance shift button raises the pressure in the trans. Makes it shift a little harder.
